Not sure exactly what it is, but something doesnt look right
Old Jun 17, 2008 | 09:47 AM
Jay351's Avatar
If it was aligned with a good idler arm, when you replace it it should fall back into spec.
Old Jun 17, 2008 | 02:41 PM
thook's Avatar
IF it was aligned....sure. But, how many times have you seen old, failing IFS steering components with a good alignment? Consider, if a vehicle was aligned recently enough, it would stand to reason the person doing it would notice a bad ilder arm....or tie rods...or pitman, blah, blah. If that failure is from age, it's been bad for a good while. Probably not aligned in a long time, either. Notice the long standing rust!
I very well could be totally wrong, but it simply doesn't hurt to check these things. You know....inspection sort of thing?
Old Jun 17, 2008 | 03:01 PM
crews462's Avatar
Agree with thook, i did my idler arm and said f#$ it on the alignment, ate through two front 31X10.50 in no time, she was toed in BAD. Get it aligned to save being mad at yourself
Old Jun 17, 2008 | 03:08 PM
mt_goat's Avatar
Alignments are cheaper than rubber. If you can't afford to have an alignment done, do it yourself:
https://www.yotatech.com/forums/f116...t-pics-115273/
