no start with electrical problem
Old Oct 21, 2006 | 12:51 AM
88-4RUNA's Avatar
Unhappy no start with electrical problem
as i was driving home tonight i heard a pop sound which was then followed with all my interior lights going out, including the cluster light, and rear brake lights . The fuel and heating gauge arent working aswell. The headlights still work. After turning the car off, it wont even attempt to start or click. Is there a fuse that would cause this situation? I tried searching and only found one person with a similiar situation but no update on how it was fixed. tia.
Old Oct 21, 2006 | 01:18 AM
Elton's Avatar
check the big fuses under the hood
Old Oct 30, 2006 | 08:56 PM
88-4RUNA's Avatar
the 40a fuse keeps burning. Guys i suck at electrical stuff what should i check? I assume this means there is a short. Any help so i can tackle this problem this weekend. thanks.
Old Oct 30, 2006 | 08:58 PM
Elton's Avatar
how are all the battery cables ?
Old Oct 30, 2006 | 09:02 PM
4Crawler's Avatar
Get a factory service manual wiring diagram and disconnect as many fuses that are fed off the 40a fuse and see if a new fuse still blows. If not, plug in a fuse at a time until the 40a goes, then trace what is on the circuit fed by the last fuse you inserted. Check all the large gauge wires for shorts, melted or damaged insulation, etc.
Old Oct 30, 2006 | 09:16 PM
88-4RUNA's Avatar
any place online where i can find the wiring diagram?
Old Oct 30, 2006 | 10:53 PM
esoterik's Avatar
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Theres a full service manual that can help you.
Old Oct 31, 2006 | 09:58 PM
88-4RUNA's Avatar
Esoterik, is that wiring diagram only for a 93+? The fuses and location are different from an 88, is the flow/path the same?
Guys forgot to mention this fuse blows without even turning the ign to on, Does that make any difference as to where to check? Would this indicate to check any line before the 40a fuse?
Old Nov 1, 2006 | 01:22 AM
rezrunner92's Avatar
You need to get the FSM that is particular to your model year, small items might be different and you may find that the factory wiring was changed mid year making all the opinions useless.
Old Nov 1, 2006 | 01:23 AM
Maybe search for wiring diagram, when I did it the correct ne for your truck was the third down.
NEVER FORGET, free advice can easily cost yo more than triple what the dealer or a reputable pro would charge you to fox this problem.
Old Nov 1, 2006 | 01:14 PM
dcg9381's Avatar
Email me, I've got one for an 88.
Old Nov 3, 2006 | 11:54 AM
88-4RUNA's Avatar
PM sent.
Regency
20
Jan 3, 2020 07:43 PM
noahstancik
Jul 10, 2015 11:18 AM
bigblue82
10
Jul 6, 2015 08:27 AM
aciorba23
Jun 29, 2015 04:18 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
