no start 1994 camry v6 xle
Old Jul 20, 2018 | 02:29 AM
luci1957's Avatar
when i turn on ignition i see 12 v at the circuit opening relay for the fuel pump ,but when i crank the engine the voltage drops to 0 volts at the relay
Old Jul 21, 2018 | 11:00 AM
RAD4Runner's Avatar
Share schematic?
Old Jul 21, 2018 | 11:22 AM
scope103's Avatar
Here's a schematic for a 2001 (it looks so similar to the one for my '94 truck, that I'll bet this one is 99% applicable to luci1957's Camry).
https://www.autozone.com/repairguide...6b43f8037894d#
When you say the voltage drops to 0 "at" the relay, tell us what you mean. If you're measuring the voltage actually at the relay, there are four pins, and each should have a different voltage. If pin 1, probably a bad ignition switch. If pin 3, could be a short in the wiring to the fuel pump. You get the idea.
Having said all that, this site is designed for Toyota truck owners. We're happy to help, but I'm sure you can find someone who knows a lot more about your rig.
kinzer
23
Nov 30, 2014 06:44 AM
E30RUNNER
Oct 7, 2009 11:39 AM
Sundarpn
Oct 15, 2006 06:28 PM
