No more Yota
Old Oct 29, 2011 | 12:01 PM
  #241
Beaniam's Avatar
sorry been a while since I checked this, I only had death wobble when I mounted my 39.5's and didn't balance them. Went away after I balanced them. The clunking could be the front driveshaft CV. They don't like having much of an angle without clearancing them and having the front end lifted 4-6" on new springs plus a regular low pinion 3rd pretty much maxes them out. My front end still clunks but I'm pretty sure it's just from that double cardan wearing out.
I've lowered the truck down about 4" and added 1.5" wheel spacers all around. Drives so much better. Front end still needs some bumpstop and shock tweaking. Also still need to get around to tubbing the firewall.
Old Nov 25, 2011 | 05:16 PM
  #242
Beaniam's Avatar
Started a bed bob/frame chop today. Hanging the shackles off the back of the frame as well. Got about half done.
Taking out 15"
Old Nov 26, 2011 | 05:33 PM
  #243
Beaniam's Avatar
Old Nov 27, 2011 | 05:58 PM
  #244
Beaniam's Avatar
Old Nov 27, 2011 | 06:16 PM
  #245
bryce_dielman's Avatar
haha
Originally Posted by SwampThing
Yeah you get more shock travel when you do em like that. I need to do that also...
You'll also need to get yourself a piece of square or round tube to "triangulate" it, unless you plan on jerry-riggin it to that spare tire tube thingamajigger.
Plywood-two by four bed lift?^
Old Dec 11, 2011 | 03:10 PM
  #246
Beaniam's Avatar
finished the rear and did like the 5th suspension overhaul since the sas, also pushed the front axle forward another 2".
Old Jan 13, 2012 | 04:06 PM
  #247
Beaniam's Avatar
overheated and finished off the already iffy head gasket last week. rather than bandaid the 250k bottom end with a new HG I picked up this crap today.
Freshly rebuilt 22ret long block.
The bad, turbo shaft has play so I'll be rebuilding or finding a ct26. Also the exhaust manifold is cracked and was repaired and cracked again so I'll have to figure that one out too.
The guy took just about everything from the turbo 4 runner and it now resides in these boxes, even the digital dash.
Old Jan 13, 2012 | 05:16 PM
  #248
peow130's Avatar
Heat the manifold up on your barbeque, weld it with high nickel rod or wire, cool it slowly. Otherwise it'll just crack again.
Old Jan 13, 2012 | 07:01 PM
  #249
badcompany's Avatar
awsome . im speechless, its
great
Old Jan 14, 2012 | 10:09 AM
  #250
1990yota-pickup's Avatar
To stop the crack for
Spreading dril a small hole at each end of the crack, then do like what's his name said and put it in the oven and heat up then break out the welding. Just think you could have the old lady serve it to you on a cookie sheet from the kitchen to the garage then you could lay a bead
Old Jan 14, 2012 | 02:05 PM
  #251
SuperToy86's Avatar
Talk bout a happy ending to a bad story!!! Whered you get your guard at? Im lookin to buildin my rig when i get home and thats the first front end ive seen that catches my eye.
Old Jan 14, 2012 | 06:17 PM
  #252
Beaniam's Avatar
The bumper was a prebent/cut tube kit from frontier 4x4 and I used a trailgear winch plate to build off of.
I also read that drilling holes along the crack itself in addition to the ends and putting steel pins in before welding also was a good idea? I haven't looked at the turbine housing on the ct20 yet but I'm guessing it's cracked by the wastegate as well.
Old Jan 15, 2012 | 04:22 AM
  #253
Get a turbo rebuild kit and slap it together
Old Jan 15, 2012 | 05:28 AM
  #254
Beaniam's Avatar
that's the plan, hoping the ct20 is in good enough shape to run until I figure out what I'm going to put on it
Old Jan 15, 2012 | 07:59 AM
  #255
yotaman85's Avatar
Love the truck, love the story. The 22ret is gonna set it off.
Old Jan 15, 2012 | 02:07 PM
  #256
Beaniam's Avatar
yep the exhaust housing by the wastegate is cracked too. May try messing around with welding but I'm not putting much faith in this ct20 ever going back on the motor
Old Jan 15, 2012 | 08:43 PM
  #257
Fireball81's Avatar
Dang man, When I saw that tree sitting there on the back of your truck my heart sank. Your determination is admirable but mabey your nickname should be the heartbreak kid.
But seriously, Sweet rig bro, keep it up.
Old Nov 12, 2012 | 07:04 PM
  #258
Beaniam's Avatar
Haven't been around here in a long while.
Toyota rear out, 14 bolt in.
Needs some wheels for my iroks.
Old Nov 13, 2012 | 06:20 PM
  #259
Beaniam's Avatar
pulling the front end this weekend. built trailgear housing, hp fj80 and longfields, trading it for a 83 srw chevy 60 and $400.
Old Dec 11, 2013 | 09:58 AM
  #260
87blyota's Avatar
Originally Posted by Beaniam
thanks for the comments
as it sits today.
what it will soon sit on
what lift are you running in the top picture?
