No-Cut ZUK Mod...our turn
Old Dec 22, 2014 | 10:12 AM
  #121
punks_is_4x4's Avatar
Do you use front or rear springs from the cj ?
Old Dec 22, 2014 | 10:16 AM
  #122
DJ99's Avatar
On my mod, I used front springs, cut down a bit. The large diameter coil fits over the top bump stopper very well, and the smaller diameter coil fits over the bottom rubber bump stop, centering it.
Old Dec 22, 2014 | 12:02 PM
  #123
Angle grinder with a cutting blade sufficient?
Old Dec 22, 2014 | 12:03 PM
  #124
Would I cut just enough to fit around the bump stop snug
  #125
DJ99's Avatar
That's exactly what I used. I cut mine down to reduce the amount of lift. It probably doesn't matter where to cut it.
Old Dec 22, 2014 | 02:27 PM
  #126
It would be interesting to put a go pro watching them perform to see if there is any weak points to the mod
Old Dec 22, 2014 | 02:37 PM
  #127
RAD4Runner's Avatar
NAH! -- Too much detail. Just check full droop and make sure it's no longer than your spring.
Old Dec 29, 2014 | 05:09 PM
  #128
frankenfab's Avatar
eager to keep this going/ordered my springs today. Will post results when they show... Stoked on fixes such as this that are for normal people that drive their 4x4 to work everyday but still want it to walk up trails here and there.
(***by that I mean... your truck can't be a super rad crawler because its your only truck)
Old Dec 30, 2014 | 12:04 PM
  #129
morena67's Avatar
Subscribed... !!!
Old Dec 30, 2014 | 01:44 PM
  #130
rustED's Avatar
*free springs*
I have a set of jeep TJ front coils that I cut down, they raised my sagging rear approx. 3" on my 86' 4Runner. They served me well for 2 years until I got my new AllPro rear lift installed. If anyone wants them they are welcome to them (just pay shipping) time to pass them on to someone that can use them!
Old Dec 30, 2014 | 05:56 PM
  #131
frankenfab's Avatar
Ordered my springs yesterday using the ebay link...AJ from the sellers account was careful to contact me to insure I got the correct spring rate/was super cool... Price for me was about $93 with shipping. Let AJ know to check this thread out- maybe make a non ebay deal for folks that hit him up through Yotatech.
Anyhow... they're on the way.
Old Jan 12, 2015 | 04:29 AM
  #132
T-runner88's Avatar
Still got the springs
I was wonderng if you still had the springs I'd be interested. I live in 85546.
Old Jan 12, 2015 | 09:24 AM
  #133
rustED's Avatar
PM sent... *Edit, springs are gone*
Old Jan 23, 2015 | 10:32 AM
  #134
WODAYODA's Avatar
Originally Posted by mschein1
I have a pickup and not runner, so is it still the same? And thanks for a quick reply, may have to order these today!
same here, what should be done?
Old Mar 17, 2015 | 10:55 AM
  #135
rusty904's Avatar
So I'd like to do this mod on my 88 4runner but I'd feel better if I could avoid metal on metal contact. Would something like this work? http://www.ebay.com/itm/Energy-4-6101R-Coil-Spring-Insulator-Set-Rear-Upper-Lower-/121597687924?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c4fc97874&vxp=mtr
If so, anyone know where I could find some to fit the 5" springs the OP used?
Old Mar 17, 2015 | 11:56 PM
  #136
RAD4Runner's Avatar
Originally Posted by rusty904
...I'd feel better if I could avoid metal on metal contact. Would something like this work? Energy 4 6101R Coil Spring Insulator Set Rear Upper Lower | eBay
Good find!
Good idea to not have metal to metal contact. I shopped for similar myself but did not find this.
It would really depend on which spring you plan to use and dimensions of the insulators.
If you do find out dimensions, please share on ur build post.
Old Mar 18, 2015 | 04:49 AM
  #137
rusty904's Avatar
I was planning on trying the same spring size as the OP but most of the spring isolators/insulators I've found are just labeled for the make and model of the vehicle rather than dimensions. I may try calling JEGS or Summit, they seem to have a lot of them.
For those of you that have used XJ or TJ springs, what's the internal diameter? Similiar to the black magic springs?
Old Mar 12, 2017 | 08:32 AM
  #138
Ingmar's Avatar
Hey guys,
First time post on the forum but i've reading for a long time and its helped out a lot! , I previously did this no cut zuk mod on my 87 4runner as a temporary fix for the sagging springs but now I just finished replacing the leaf springs so I have the coil springs left over. They are the Blackmagic 11" springs. I don't want to throw them out so if anyone in the SoCal area needs them to perform this mod you a welcome to have them for free if you come to pick them up.
(sorry for posting on this thread tried to post to the classified section but it said i did not have account permissions)
Just shoot a PM if you want them!
Old Mar 12, 2017 | 01:06 PM
  #139
RAD4Runner's Avatar
Originally Posted by Ingmar
... I just finished replacing the leaf springs so I have the coil springs left over. They are the Blackmagic 11" springs. I don't want to throw them out so if anyone in the SoCal area needs them to perform this mod you a welcome to have them for free if you come to pick them up.
Really nice of you, Sir!
I'm curious... What replacement springs did you use, and how your rear suspension sits now? Got distance from lip of wheelwell to edge of rim (15-inch)? TIA
Old Mar 13, 2017 | 04:40 PM
  #140
Ingmar's Avatar
Hi Rad 4Runner,
I used the OME Leaf springs as a replacement, it was a pretty straight forward install but a serious workout.
Right now its exactly 15 inches but I think it will settle down a bit.
