No brake pedal on my 89 pickup
I have no pedal at all. I have changed the mc, the booster, and went through almost a half-gallon of fluid bleeding the brakes. We have bench bled the master. I have bled all four tires and the LSPV. The only place where air comes out is in the left rear. We bled it for twenty minutes and still had air coming out of it. I have searched everything brake related and can't find anything that is similar to this.
From: Downtown Heckronto, Ontario, Soviet Canuckistan
Have you checked the wheel cylinder? Pop the drum off and give it the once-over, see if it's leaking anywhere.
If it's bad, replace the wheel cylinders on both sides.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
