No brake pedal on my 89 pickup
Old Jun 17, 2010 | 04:08 PM
wmayota's Avatar
I have no pedal at all. I have changed the mc, the booster, and went through almost a half-gallon of fluid bleeding the brakes. We have bench bled the master. I have bled all four tires and the LSPV. The only place where air comes out is in the left rear. We bled it for twenty minutes and still had air coming out of it. I have searched everything brake related and can't find anything that is similar to this.
Old Jun 17, 2010 | 04:13 PM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
Have you checked the wheel cylinder? Pop the drum off and give it the once-over, see if it's leaking anywhere.
If it's bad, replace the wheel cylinders on both sides.
Old Jun 17, 2010 | 04:16 PM
wmayota's Avatar
Thanks for the quick reply
Checked the wheel cylinder, no leaking fluid
Old Jun 17, 2010 | 04:25 PM
wmayota's Avatar
Just double checked it, theres a slight weep and the adjuster was off...
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
87turboPA
Jul 12, 2015 07:49 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
