Newbies first rebuild and started! NOW I NEED A LITTLE HELP!
Old Apr 4, 2011 | 01:54 PM
summit4runner's Avatar
can someone I.D. this hose?
Hey guys, just finishing rebuild. This is the last hose, can't figure out where it goes. It the one comoing out of the boot at the firewall.
Old Apr 4, 2011 | 01:57 PM
toyota4x4907's Avatar
A/C line.
Old Apr 4, 2011 | 02:04 PM
iamsuperbleeder's Avatar
yup, the condensation tube
just let it dangle strait down; DO NOT CAP IT OFF
Old Apr 4, 2011 | 02:18 PM
Cool, thanks guys.
I was actuallt just debating not hooking the a/c back up. I live at about 10,000' in CO so I never need it.
Is it that simple, just don't put it back on?
Old Apr 4, 2011 | 02:24 PM
yeah that open end that you see just remains open and dangles straight down
when the AC is on, condensation is produced. it accumulates and drips out that hose and onto the ground under the truck
Old Apr 4, 2011 | 02:25 PM
xxxtreme22r's Avatar
no it's supposed to be off, it's to drain condensation from the ???? evap ?????, just make sure it's pointed down and not dripping over parts.
Old Apr 4, 2011 | 02:36 PM
Yep, it will stay off, dangling down, thanks a lot, this place is REALLY helpful!
If I do not put the AC unit back on, leave the 2 hoses for it unplugged, and obviously dont put the belt on, will that cause me any problems?
Old Apr 5, 2011 | 08:04 AM
removing my AC unit
I just finished a rebuild on my 1988 22RE. I want to take the AC unit off b/c I never use it. (I live in Colorado @ 10,000').
I see it's on its own separate belt that doesn't power anything else.
It's been discharged and I have the two hoses that go into the unit hanging down as well as the wire to the harness.
Can I just leave everything unplugged and run it, then eventually cut the hoses out?
Old Apr 5, 2011 | 08:10 AM
waskillywabbit's Avatar
Yep. Leave the compressor bracket bolted up.
:wabbit2:
Old Apr 5, 2011 | 08:15 AM
irab88's Avatar
on board air, ftw!
Old Apr 5, 2011 | 08:23 AM
Ok, off it goes.
Why should I leave the bracket on?
I think there are some bolts that go through the timing chain cover, but I was just going to buy shorter ones.
Old Apr 5, 2011 | 11:40 AM
waskillywabbit, how come you say leave the bracket on?
Old Apr 5, 2011 | 11:42 AM
Unless you got the right length bolts for certain just leave on the bracket.
:wabbit2:
Old Apr 5, 2011 | 11:44 AM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
e: guess not
voting oba still, might as well make use of that bracket
Old Apr 5, 2011 | 11:45 AM
BigBluePile's Avatar
I'd put a new bearing in the compressor pulley and verify the clutch clearance (which is what I'm doing currently) and convert it to oba. IIRC there are a few bolts that go thru the timing cover...
Old Apr 5, 2011 | 12:18 PM
OK, so I will double check the bolts that go through the cover.
BTW, what does convert to OBA mean?
Old Apr 5, 2011 | 12:25 PM
Junkers88's Avatar
OBA= On Board Air. You use your AC compressor as an air compressor. With a little plumbing and an air tank, in line oiler and a dryer (not sure on the dryer) you can air up the tires, run air tools etc.... and it's freaking cool since everything is in the factory location.
I looked into this a while back but never got around to messing with it. I might need AC this summer in New Mexico.
Old Apr 5, 2011 | 12:48 PM
That is next on my list then, awesome.
Old Apr 9, 2011 | 02:44 PM
OK. So I just did my rebuild, I've never done anything more than a timing chain. I followed everthing to the tee in the manuals and double checked it.
It started right up, but is shaking (the whole motor) and seems to have low RPM's. Giving it a little steady gas will make the shaking stop and it sounds great. I've already maxed out the idle adjust screw.
Where should I start with the fine tuning?
Or do I need to go do a break in drive first?
ANY help, advice, comments appreciated.
Chris
Old Apr 9, 2011 | 05:09 PM
low idle, screw already maxed out.
OK. So I just did my rebuild. I followed everthing in the manuals and double checked it.
It started, but is shaking (the whole motor) and seems to have low RPM's. Giving it a little steady gas will make the shaking stop and it sounds great. I've already maxed out the idle adjust screw which helped a little, but seems to need more.
Where should I start?
Timing?
TDC was set correct from cam to crank.
Had to do some trial and error on the distributor timing.
Should I just do a break in drive and see if it improves?
