newb Tire size question, 225s or 31s stock?
Old Sep 22, 2006 | 07:00 PM
grant's Avatar
Quick newb question:
I just picked up a new-to-me '91 4Runner SR5 6 cylinder 4x4. The odometer reads 305xxx, but the engine runs like a champ. Very clean for the year. I enjoy the heck out of so far. I talked to the dealer and found out the previous owner had the HG recall done back in '01. I have already scheduled to have the steering rod relay recall done next week.
My question is: The door jamb sticker listing tire pressure makes note of a 225/75 tire size. But my owners manual mentions that the 3VZ-E engine (which I have) uses a 31x10.5 tire. My truck is equipped with a 31x10.5. Up to this point I thought the previous owner upgraded the tire size, due to my seeing 225/75 in the door jamb. But after reading the manual, I'm starting to think my truck came with the 31s. I guess I'm wondering why there is a disrepancy between what is listed on the door jamb and what is printed in the manual.
It's not a huge deal, but I'd like to know so I can calculate mpg and see if my odometer is actually correct.
Any comments appreciated.
Thanks.
Old Sep 22, 2006 | 07:27 PM
toddowaddo's Avatar
My '94 has the same 225/75 info on the door jamb, but it was bought new with 31's. Not sure how you could ever know for sure. I'd bet it came with 31's since it's an SR5 but I've been wrong before. What kind of gearing do you have?
Old Sep 22, 2006 | 08:09 PM
Elton's Avatar
ya those door jam tags dont help when i had my 91 it had the 31'' tire package and the jam said 225s ive always put 34psi in all my rigs ive owned
Old Sep 22, 2006 | 08:10 PM
CJM's Avatar
CJM
If its an sr5 there was most likely an option for 31's, my t100 came the same way and I have the window sticker that denotes it was an upgrade from 235's.
Old Sep 22, 2006 | 08:15 PM
keithguts's Avatar
The 31's is a manf. option. I also have a 95 runner, and it came with 31". but keep in mind, I bought it used so I belive the person I got it from put them on as from the dealer they come with 225/75r
Keith
Old Sep 25, 2006 | 08:58 AM
grant's Avatar
interesting. i'm not sure what gearing i have. i think i'll just bust out the GPS and cruise down the highway and see if my gps speed and mph on the dash read the same.
thanks for the replies.
Old Sep 25, 2006 | 09:56 AM
TNRabbit's Avatar
I have a '94 xtracap p/u that has 31x10.50s; it's completely stock & my speedo is actually a couple of mph's FAST, if you can believe that....
Old Sep 25, 2006 | 01:07 PM
187-Proof's Avatar
Well I have been researching this issue and I am not sure either. My 4Runner also says 225/75 on the door plate but has 31's on it. I bought it used so I don't really know for sure...but it seems to be a common occurance.
What I did find interesting though is that the other codes in the door jam will tell you what type of gears/tranny/# of pinions/third member you have. My 4runner says G144/A340H which means I have an 8" ring gear, 4.875 gears, 4 pinions in the carrier, and the auto tranny.
Like I said before my plate also says factory tire size of 225/75, but if I have 4.88 gears wouldn't that be insane with P225's? I wonder what Toyota was thinking. My truck is slow as a turtle now with the 31's, and it is my understanding that going to a smaller tire would increase my acceleration, but decrease my top end. I cannot figure out how with 4.88s and 31's my truck is so slow. Most vehicles that have 4.88 would normally have a 35" + tire.
Old Sep 25, 2006 | 02:49 PM
95yoda's Avatar
I have 31s on my 95 pickup and my speedo is slow, seems close at low speeds but my 60-70 its 7 or 8 off.
My odometer seems to not jive with mile markers either. i wonder if that makes my miles read fast or slow?
Old Sep 25, 2006 | 03:00 PM
da_bigg_wigg's Avatar
Although your runner has quite a few kilometers on it, try this trick: look at the spare tire and see whats on there. If its still the original spare, itll be whatever size came with the truck. I've got an untouched dueler hanging under there. Too bad my rear bumper is a little mangled and I can't even get the rod in there to lower the tire. When I get a flat, I'm just gonna hope I can get a hacksaw in there... :/
Old Sep 25, 2006 | 04:26 PM
Paul H.'s Avatar
For 2nd gen. Autos. The 31" tires come with 4:88's while the 225's come with 4:56. The spare is really the best way to tell which tire your truck came with. If the rod goes straight in from the bumper then your's came with 225's. If it has to go in at an angle then you have 31's. This is according to my manual. The tire sticker on the door jab means nothing.
Old Oct 10, 2006 | 12:34 PM
187-Proof's Avatar
I found that if you go to Toyota.com and give them your VIN # they will give you all the info you want on your truck.
kazuya2416
Apr 5, 2024 02:17 AM
djpg2000
Nov 11, 2020 04:56 AM
Sep 4, 2015 09:27 AM
Yotoder865
Jul 9, 2015 07:51 PM
