new seals for bearings (what are they called)
I don't remember any brass....
With the hub off, the outer bearing should just fall out. Look towards the inside and you should see the inner bearing. The only thing holding that on at this point is the seal itself. It should have a rubber inner piece attached to a metal middle piece, attached to a rubber outer piece (aka the seal). Just pop that off. A seal puller works best, but a needle nose/screw driver will work in this case.
Thanks.
jasonty
41
Dec 23, 2018 01:00 PM
FS[PacSouthWest]: FS: A340 transmission and t/case Lancaster Ca
4x4-runner
Dec 27, 2016 01:58 PM
Iceman4193
Aug 28, 2015 08:43 PM
Iceman4193
Jul 15, 2015 04:48 PM
