New remanufactured 3vze engine, Running Rough. *tear*
Old Aug 25, 2007 | 07:10 AM
monst's Avatar
Unhappy New remanufactured 3vze engine, Running Rough. *tear*
I threw a rod in my old engine, so i went ahead an decided to get a new engine.
I got the remanufactured engine professional installed. They did all new belts, knock sensor, new gaskets.
I ride with the mechanic Thursday and it rides great did a 5 mile lap.
I get the truck back Friday, Drive it around it runs nice and smooth.
On the way home Friday im doing about 55-70 traffic is fluxing. I noticed im losing a little power, Ill be in 4 or 5 gear at 3000rpm and it the gas and not accelerate. This gets better while driving. Figure maybe im just breaking in the engine. I get the truck home and park it, then go to pick up a friend and i notice like a shake or rumble. It happens very noticeably when Im in third gear at about 3000rpm then let of the gas promptly, it shakes or has a slow vibration.
Any insight on what the problem could be? or a way to check for something. The engine light didn't come on, but i also noticed the cruse control hasnt worked since i got it back.
Could it have to do with the transmission?
Old Aug 25, 2007 | 07:49 AM
shoes138's Avatar
check your wires make sure they are all connected
Old Aug 25, 2007 | 07:50 AM
monst's Avatar
Ill go double check that, but if a wire was disconnected i would assume it would run rough on acceleration, through all gears.
Old Aug 25, 2007 | 08:03 AM
shoes138's Avatar
mmmm....true! sry i just woke up n thats the first thing that popped in my head!
Old Aug 25, 2007 | 08:09 AM
monst's Avatar
i just did a lap around the block, seems it does it on any gear, but it doesn't seem do it through the whole RPM spectrum.
Old Aug 25, 2007 | 08:24 AM
shoes138's Avatar
does it only do during low rpms now or high?
Old Aug 25, 2007 | 08:40 AM
monst's Avatar
Ok it seems to do it through every gear, and every rpm, it just more noticeable in some rpms 2500-3000, and VERY noticeable on deceleration, or gearing down.
I checked the wires, and the distributor cap, they seem to be on good, i cant really reach the plugs.
Old Aug 25, 2007 | 08:48 AM
TNRabbit's Avatar
Is it an engine or drive train vibration ? Double check all connections underneath for the tranny. When I completed my rebuild, I drove almost 100 miles with all the cross-member bolts backed out 90%!! This cause some unusual noises but all was well when I torqued them down.
Old Aug 25, 2007 | 08:49 AM
Kaleb's Avatar
Contact the people that installed it for you. You should have some sort of warranty.
Old Aug 25, 2007 | 10:30 AM
Tim_Snapple76's Avatar
x2
thats why you pay high dollar... to have them do it right.the first time. send it back.
Old Aug 25, 2007 | 10:50 AM
crolison's Avatar
Yeah seems like they screwed up, take it back.
Old Aug 25, 2007 | 07:14 PM
wrekt-1's Avatar
x3 on the return to installer.
On a bad note I did my own rebuild. Same issues, rough idle and rough running. All other signs pointed to electrical or injector or along those lines. Did a silly compression check just to make sure....Sure as , I got a weak one. You should try pullin your plugs one by one to check if it is dragging a cylinder. g/l!
Old Aug 25, 2007 | 09:42 PM
monst's Avatar
Having it towed back to the shop tomorrow. I'm glad their work is guaranteed.
Old Aug 26, 2007 | 06:22 PM
let us know what they/you find. tim.
Old Aug 27, 2007 | 04:58 AM
monst's Avatar
Just talked to them, they are picking it up tomorrow morning.
noahstancik
Jul 10, 2015 11:18 AM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
ra72
Jun 16, 2015 11:10 AM
