New to me 89 4Runner
Old Sep 5, 2017 | 06:54 AM
  #121
joelsmithdesigns's Avatar
quick rundown of what I was talking about earlier
had to rewire the plug going to the fuel sending unit this weekend and thought I'd snap a few pictures of what I was talking about earlier and the hot rod wiring trick someone showed me....
Don't forget the heat shrink!
ends split into "Y"s
"Y"s go together
Twist each side together (clockwise)
Twist both twisted sides together and lay flat against the wire to slip heat shrink over
Old Sep 5, 2017 | 08:53 AM
  #122
scope103's Avatar
I would expect that connection to have very little mechanical strength.
In house wiring (all indoors), wire nuts screw the wires together. In a printed circuit board, solder holds the components to the board. In automotive, crimping holds the wire to the connector. All time-tested methods for their specific applications.
(Solder alone on loose wires like that is only modestly stronger than simple twisting. There is a reason Toyota, and every other manufacturer, use crimped connectors.)
It's your truck, your choice.
Old Sep 5, 2017 | 11:39 AM
  #123
RAD4Runner's Avatar
+1
Plus without tight contact between the copper surfaces, they would be more likely to corrode.
...In automotive, crimping holds the wire to the connector. All time-tested methods for their specific applications. (Solder alone on loose wires like that is only modestly stronger than simple twisting.
+1
For my truck, I like some mechanical integrity of twisting wires well, then solder to add a little more mechanical integrity and to fill gaps and minimize chance for corrosion, then heat shrinking for a little more mechanical integrity. For connections close to battery, I crimp, solder, brush on liquid insulation and heat-shrink.
Example (My "B" wire upgrade):
I also use parallel that produce copper wire to copper wire contact, not butt-connector crimp that produce copper wire to thin/brittle butt-connector metal to copper wire contact:
Old Sep 5, 2017 | 07:00 PM
  #124
flg8r22's Avatar
Originally Posted by coryc85
Tony - roof rack looks good, and man that 89 shines up really nice. Speaking of Hurricane Irma, not looking good for South FL right now, just went up to a cat 5 and we are in the cone, hoping this one misses us!
Thanks Cory! It's not looking good as far as the hurricane is concerned especially where your at. I will be wrapping up all my prep tomorrow and will make a decision on stay or go by early Friday morning. I hope you and yours stay safe. If I can help with anything let me know. T
As far as the wiring goes, I ended up using marine electrical connectors for my repair. Grabbed a handful from the boat shop. Crimp on then heat shrink the inner end. So far so good for my first electrical repair. Time will tell. Thanks for everyone's input. I try to soak in as much knowledge from y'all as my brain will allow. Ray, your pics are top notch. Hurry up and do the electrical repair manual for dummies like me lol.
