need some gear advice
Old Mar 9, 2008 | 05:17 PM
jdw1's Avatar
ive got an 87 pu that has 31x10.5 tires, and i pull a trailer often. i have stock gears, and thinking about upgrading to a different ratio. what gears do you guys recommend for daily driving but also pulling trailer with a load. what brand is a good choice?
Old Mar 9, 2008 | 05:23 PM
TORTIS's Avatar
auto or 5 speed? i have 4:88's, and they work great, but i probably could have gone with 4:56's. i plan on stepping up to 16'' rims so 4:88's for me.
Old Mar 9, 2008 | 05:25 PM
jdw1's Avatar
i have 5 speed manual. 15" rims. what ratio are the stock gears anyway for this year?
Old Mar 9, 2008 | 06:45 PM
jdw1's Avatar
come on guys, any more opinions?
Old Mar 10, 2008 | 11:14 AM
Elvota's Avatar
Check this thread out for info on what gears you currently have:
http://toyota.off-road.com/toyota/ar....jsp?id=274535
There is a good chart at the bottom and an explanation on how to pull your axle code from the door label.
YT gets a lot of "what gears should I run" questions. Search around a bit for some more information.
31" tires are basically stock, so your stock gearing is most likely fine. Most regear for bigger tires.
What are you hoping to improve by changing your gearing?
Old Mar 10, 2008 | 11:34 AM
Djlarroc's Avatar
If you're staying with 15" rims and not going taller than a 31", I'd say 4:56. Although, the rim size doesn't really matter is the height of the tire.
Old Mar 10, 2008 | 01:57 PM
jdw1's Avatar
i hoping to improve acceleration when getting on the highway with a trailer. and in general.
Old Mar 10, 2008 | 02:01 PM
TORTIS's Avatar
4:88's with 31's pull a trailer with no problem. i carry about 800 to a 1000 pounds. what are you going to pull weight wise? i am in 5th gear a 50mph, but i short shift for gas mileage.
Old Mar 10, 2008 | 02:07 PM
jdw1's Avatar
i will pull 1000-3000 pounds
Old Mar 10, 2008 | 03:51 PM
TORTIS's Avatar
i think 4:88's. 5:29 gears would mean no highway speed. pulling that much weight is going to be hell on your 5th gear bearing, if you have a W56. keep it in fourth if you can. where in texas are you?
Old Mar 10, 2008 | 04:37 PM
jdw1's Avatar
about 30 minutes south of dallas
Old Mar 10, 2008 | 04:42 PM
TORTIS's Avatar
no such thing as 30 minute south of dallas. dallas runs all the way to waco..
icentropy
Sep 16, 2020 02:47 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
Iceman4193
Jul 15, 2015 04:48 PM
