NEED HELP Pinion Nut Wont Budge
Old Oct 26, 2009 | 10:32 AM
90runnerfan's Avatar
so just finished doin lockright install and i am going back together but the freakin pinion nut will not come off ive seen the good write up on 4crawler but the damn nut is unlocked and i am stuck completely! ive heated it up (scetchy since the gas tank is right there) but nothing seams to work
thank you
Old Oct 26, 2009 | 10:41 AM
bugs1961's Avatar
Sounds like you may need a bigger "hammer". I use a 3' piece of steel pipe on my 1/2" drive breaker bar to loosen really tight bolts and nuts (crank pulley, CV hub nuts, etc).
Old Oct 26, 2009 | 10:43 AM
just thinking dremel it off anyone done that? at least till the locking part comes off and then maybe it will budge?
Old Oct 26, 2009 | 10:50 AM
4Crawler's Avatar
X2 on the pipe over the breaker bar handle. I needed to do that same to break the t-case flange nut loose on my '85. I had that length of pipe bent into a good arc before the nut slowly released. I had tried the regular breaker bar and two different impact guns and none of those budged the nut.
Old Oct 26, 2009 | 11:03 AM
toyospearo's Avatar
X3! Thats the method I used. Came right off.
Old Oct 26, 2009 | 03:37 PM
Well thanks all didnt have a breaker bar but i did have a exhaust bracket off a harley that did the same job hahahahaha
Old Oct 26, 2009 | 04:56 PM
yoterr's Avatar
ive used a piece of pipe on a ratchet braced on the frame, and put the sucker n 4lo and reverse
Old Oct 26, 2009 | 05:17 PM
waskillywabbit's Avatar
Never had any issue just using a honking impact.
kawazx636
Oct 6, 2021 03:03 PM
voiddweller
Oct 2, 2015 07:47 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
