Need help with 22rte starting issue.
Old Mar 11, 2015 | 07:31 PM
Brodie86's Avatar
My 4runner starts then dies after about 1-2 seconds.
I put a jumper in the connector to check the codes and got #6. Tried a short time later to start it and it fired right up and idled good. I went to close the hood for a short test drive and saw the jumper still in and it died when I pulled it. It will start with the jumper in place and run great until it gets completely warmed up. Once warm it dies after a second with or without the jumper.
I'm lost on this thing.
Thanks in advance for any help.
Old Mar 11, 2015 | 08:17 PM
abecedarian's Avatar
Code 6 is a loss of RPM signal to the ECU. Likely causes are igniter, igniter circuit, distributor or ECU, wiring associated with these.
It will start and run off the Igniter signals for a short period since the igniter reads the distributor, fires the coil according to the baseline settings and sends signals to the ECU but if the ECU doesn't jump in and take over within a few moments, the engine will die.
Check all the connections to / from the distributor to the igniter for corrosion, check terminals are firmly seated in the connectors. Make sure the wires aren't broken or frayed where the terminals are crimped on.
Old Mar 11, 2015 | 08:22 PM
Brodie86's Avatar
I'll start looking over those connections along with checking any grounds I can find tomorrow.
Any idea why it runs until warm with the jumper wire?
Old Mar 11, 2015 | 10:42 PM
grumpin's Avatar
Why does it do that when it has a "back up circuit"? This is good to know.
Old Mar 12, 2015 | 06:48 AM
Brodie86's Avatar
Connections look good and clean and feel tight when connected.
Anyone know where I can find FSM? I have only found bits and pieces so far.
Old Mar 12, 2015 | 03:27 PM
grumpin's Avatar
Here's one...
http://www.ebay.com/itm/261805284756?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Mar 12, 2015 | 04:15 PM
Brodie86's Avatar
I quit my job 2 days ago, I wont be buying that just yet lol
As for the 4runner, I pulled the lid off the air box to check it with an ohm meter and all checked out good. Put it back together and it started up and runs and drives great for now..
This is the second time I've had these symptoms and last time it was a loose clamp between the turbo and air box. I guess I'll just see how long it lasts this time. I was lost before and definitely wont be able to figure anything out when its running good.
bigjstang
Jun 2, 2025 03:56 PM
Doug4320
Mar 24, 2018 10:11 PM
nick b
Jul 11, 2015 04:38 AM
Poncho0206
Jul 10, 2015 06:21 PM
karbin
Jul 5, 2015 11:37 PM
