Need advice for replacing transmission bearings and seals on '86 4Runner
I removed my rear drive shaft yesterday and tried to get the u-joint out with a hammer and socket. Unsuccessful. One of the caps was broken, so I'm sure getting a new one will at least make a difference with my bad vibrations at high speeds. But, because it was broken I wasn't able to drive it through with a hammer.
So, I'm going to pick up a shop press and am wondering if this little 1 ton will do the trick: http://www.harborfreight.com/1-ton-a...ress-3552.html
Thanks for the feedback guys!
The 12 ton hydraulic press will be a lot more functional for future projects because it can be adjusted to suite large items, long objects etc. That's what I've got, its a little bulky, but worth having.
You can use a vise and sockets to get your u-joints out too. Small socket to push on the cap and larger one that it will go through. Easier than a hammer.
I bought the HF 20 ton press for about $80 on sale. Used it to rebuild my trans and diffs pluss other stuff. Sometimes I max it out to get a bearing to break loose so go bigger if you can.
I tore my trans and t-case apart because of horrible noises. I had new u-joints and my drive line angles were good, even after lifting it. Found nothing wrong. Thats a lot of work.
Ended up being me needing a CV joint put in rear drive shaft after the lift. My trans went from sounding like it was going to come apart to nice and smooth.
#25
if you can get the double cardigan (cv u-joint) for your drive lines its better because worrying about your angles it greatly diminished, my buddy did a monster truck lift on his heep wrangler, 66" tires all that stuff. and just did the cv u-joints, didn't have to do a transmission/engine drop to keep his angles.
#26
Figured I wouldn't be able to get away with using the 1 ton press, and didn't want to get a 12 or 20 ton (or higher) because I'm moving in a month and got enough to pack up and transport already.
So, I just brought the drive shaft and half-removed U joint to a local mechanic to press it out and install the new one. Wasn't my first choice, obviously, but considering I'm trying to make it to the job in my 4Runner in a couple hours, probably my best move. $35 for the work...
I'll look into CV joints and potentially using a clamp, but hopefully a press, next time.
We'll see if I'm rolling smoothly here shortly.
#27
Got the drive shaft back in and took 'er for a test drive... LIKE BUTTER! Thanks for all the info/advice guys. It was a simple fix, but empowering nonetheless. Gives me a bit more confidence approaching the tranny when the time comes. Probably sooner than later!
voiddweller
19
May 2, 2016 09:10 PM
FS[PacNorWest]: T100 auto trans/tcase - Bay area, CA
94whiterunner
Sep 22, 2015 07:25 PM
JaredL
Jun 16, 2015 04:47 PM
22r, 4runner, 86, 98, hard, input, installing, make, replacement, replacing, seal, tranny, trans, transmission, turn
