Necessary to replace head bolts?
Old Nov 18, 2008 | 10:54 PM
abecedarian's Avatar
Originally Posted by Matt16
... >snip< ...
you moron
and when have I ever disrespected you with ad hominem name calling?
Old Nov 18, 2008 | 10:57 PM
Matt16's Avatar
I really hate word games "abecedarian". You know exactly what I'm talking about, I hope you show a little maturity in the future. Why even post, if you're not contributing anything?
Old Nov 18, 2008 | 11:14 PM
sh0kk86's Avatar
3.0's are tty, 22r's arent.
with 22 yrs, 183k on mine, i replaced em
Old Nov 21, 2008 | 05:22 PM
rev. chuck's Avatar
normally i just take the grinder to the end of the bolt careful not to damage the threads couple thousands off each bolt and put em back in. i have done dozens and dozens and dozens of cars exactly like this and never had an issue.
ive been an ASE certified mechanic for 13 years. BUT if you have the money and your spending the money to do a complete rebuild. then the head bolts should be on your list of parts to buy. just makes sense.
and dont forget the rod bearings
Old Nov 21, 2008 | 06:06 PM
  #25
ovrrdrive's Avatar
For what it's worth, 22RE head bolts aren't TTY. I reused mine and have been fine now for 15k.
YMMV...
Old Nov 21, 2008 | 07:02 PM
  #26
I still wanna know why the OP is pulling the head after 15k miles.
Old Nov 21, 2008 | 07:04 PM
  #27
rev. chuck's Avatar
possibly for the same sort of reason i just replaced a BRAND new rebuilt inside and out motor with a yard motor damn oil was still brand new in it.
IDIOCY
Old Nov 21, 2008 | 07:12 PM
  #28
ovrrdrive's Avatar
I had to pull the head on my motor after only 8k when the cheap aftermarket plastic timing guide set shattered and caused my engine to jump time and bend all of my valves. I learned my lesson...
Old Nov 21, 2008 | 07:14 PM
  #29
rev. chuck's Avatar
ive been wrenching for awhile and i still dont understand 0 tolerance engines
Old Nov 21, 2008 | 07:22 PM
  #30
valve angles are often the determining factor of whether the engine is 'interference' or 'non-interference'.
valves moving near parallel to the bore often are non-interfernce while valves moving at an angle when compared to the bore centerline can cause the lip of the valve to move down into the bore farther thus making 'interference'. also, piston design, combustion chamber geometry, and other issues can make the difference.
Old Nov 21, 2008 | 07:48 PM
  #31
rev. chuck's Avatar
right what i should have said was i dont understand why they manufacture them.
Old Nov 21, 2008 | 07:55 PM
  #32
they manufacture them because sometimes the design criteria- horsepower, torque, compression, etc., intake, exhaust et al, combined with the physical constraints imposed by body lines, etc. require certain designs.
So the engineers build what they have to in order to make it work.
Old Nov 21, 2008 | 07:59 PM
  #33
rev. chuck's Avatar
would seem to me the extra thousands or so needed to stop the pistons from smacking the valve's upon failure wouldnt hurt a thing.
Old Nov 21, 2008 | 08:06 PM
  #34
it's not just machining a relief into the piston that matters.
the shape of the piston, the shape of the chamber in the head, all play a part in how the flame front moves within the combustion area, and any sharp edges cause hot spots... deep reliefs lower the compression ratio.
it sounds really simple to just say "make room for the valves", but making room for the valves has consequences.
Old Nov 21, 2008 | 08:15 PM
  #35
rev. chuck's Avatar
ok so forget the horsepower lets say on an efficiency level how can that little bit be so important to justify the gamble of total failure over a small sometimes plastic part.
leading to hundreds of dollars in DIY repair much less having to take it too a mechanic to fix.
i just dont get it.
Old Nov 21, 2008 | 09:14 PM
  #36
considering replacing the 22re timing chain (an interference engine) at the recommended service interval is cheaper than replacing the timing belt on a 3vze (a non-interference engine) at the recommended service interval (according to the time I would spend doing either), I fail to see your point.
Old Nov 22, 2008 | 11:11 AM
  #37
rev. chuck's Avatar
considering improper installation of the chain on the interference engine or failure before its service recommendation (which happens) would lead to pretty well the complete destruction of the valve train and cost alot more money then the belt on the non interference engine.
i fail to recognize your failure to see my point as a competent argument.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Jnkml
Jul 6, 2015 01:20 PM
