Near Overheating
Old Jan 22, 2008 | 05:26 PM
sethmcalister's Avatar
Near Overheating
Over the summer I installed a reman'd 22RE into my 89 pickup. Since then, I have had trouble with my truck coming close to overheating. What I mean is that when I begin to drive it heats up almost to where it is overheating but then goes down. I replaced the thermostat and the gasket, have put RTV Sealant on the housing because I had metal on metal and had a leak. Can anybody offer me any advice?
Old Jan 22, 2008 | 06:02 PM
luxdlx's Avatar
Have you checked your antifreeze? Are you running 50/50?
just a 22re's Avatar
did you blead all the air out of the cooling system? and or did you check the cooling lines are they hot cause the temp gauge in the dash sometimes goes south and works half the time so just make sure that it is deff overheating other then that im not sure of anything else as of this point in time hope it helps
Old Jan 22, 2008 | 07:22 PM
4Crawler's Avatar
See the web page section below for a possible answer:
- http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Old Jan 22, 2008 | 07:31 PM
Lifted&Lowered's Avatar
Did you replace the Tstat with a generic one (Napa, Autozone) or did you get the Toyota one? Get the Toyota one!!!
Old Jan 22, 2008 | 08:44 PM
thook's Avatar
I'll bet that's the "problem". My '86 has been doing this for years. Mostly in winter. I don't worry about it anymore.....although, I'm rebuilding partially so I'm actually going to fix it.
ladybugRC
458
Aug 21, 2020 10:41 AM
Corvoid
Dec 11, 2015 11:21 AM
alexcarey
Oct 14, 2015 06:05 PM
larrys93pickup
Sep 17, 2015 07:05 PM
LotOMiles
Sep 14, 2015 11:45 PM
