my new truck, 1990 xtra cab
Old Mar 1, 2008 | 02:10 PM
Bob_K's Avatar
Thumbs up my new truck, 1990 xtra cab
pretty excited about picking up this truck. 1990 xtra cab V6 140k miles.
The good:
only $1800 !
has a new clutch
very, very little rust.
nice leer cap
The bad:
heater switch needs new resistor (only works on high)
front seat is worn (seat covers on order)
rear end sags a bit (pro comp AAL's on the way)
one mismatched tire, the rest are 50% worn
one small rust hole on rocker panel, thinking of filling it and hitting it with primer and touch up paint
So there you have it! any reccomendations on some preventative maintnence related to this model I should look into?
Runs like a top btw!
Old Mar 1, 2008 | 02:13 PM
Allstar93088's Avatar
Nice looking truck man, Welcome! Got it for a stttteeeealll!
Old Mar 1, 2008 | 02:14 PM
camo31_10.50's Avatar
run the VIN and make sure the headgasket call has been redone on it...if it qualifies...umm..change all the fluids for sure..just to be safe..unless u have proof of them being changed by the previous owner..dated and everything...other than that...get some good M/T's and throw an E-locker in the rear..and an aussie up front..and take it ANYWHERE...thinkin about puttin lockers front and rear in my '80 pickup.
Old Mar 1, 2008 | 02:38 PM
desertyodaboy's Avatar
if the shifter bushing is worn... go buy a marlin one...makes a HUGE difference
Old Mar 1, 2008 | 02:44 PM
b.miller123's Avatar
welcome!
wanna sell you camper shell? Just kidding,
anyways, there is also a steering rod recall, I am pretty sure that your year has it too, but not 100%, pretty easy to find out, just call the dealership with your vin #
Old Mar 1, 2008 | 03:38 PM
904_runner's Avatar
Next time you take the intake plenum off, inspect the fuel pressure regulator, make sure the screw in the middles is still tight! That screw fell out on my v6, caused a fire, it was a mess! Wouldn't hurt to carry a fire extinguisher! I do!
Old Mar 1, 2008 | 05:06 PM
Vanman's Avatar
Shifter bushing...can you explain? I am curious...
Old Mar 2, 2008 | 11:01 AM
he is talking about this:
http://www.marlincrawler.com/htm/tra...rans_parts.htm
Here is another pic where the seat goes into the top of the transmission:
The seat: it's the "bushing" or whatever you want to call it the is in between the stationary "ball" part of your shifter and the "cup" that is pivots in, on top of the transmission.
The socket: it goes on the end of your shifter (past the pivot ball), it's the part that actually goes down into your tranny. Most of the time, these don't really start getting worn for some time, mine looks brand new with 140k.
If it gets really worn, falls apart, destroyed, your shifter gets really, really loose, like moving 3 inches side to side when the transmission is in gear. It's a pretty common occurrence on truck with higher miles (over 100k). BUT: if your shifter doesn't move more than an inch (either side to side or front to back) while in gear, then I wouldn't bother. You aren't going to see much, if any improvement. (best thing to do is pull the shifter and actually look at the parts before buying anything you might not need)
The marlin ones are hard plastic and the stock ones are two kinds of hard rubber. Most people on here will swear that you need to get the "heavy duty" marlin one. I got one, and it didn't seem like it was any better than what I had to begin with. Actually, at first I thought it was worse, but after replacing the marlin one with a new oem dealership one, they are about the same, play-wise.
I understand that the Marlin one would most likely last years longer, but my opinion is that a $13 part that needs replaced every 15 years or 140k miles, is not in dire need of aftermarket support for "heavy duty" items. I did go back to the oem one (because of my initial reaction of the marlin being worse than my old oem one, I went to the dealership). The oem was the last one that was in there, and if felt the same as the marlin one, so that's what I stuck with.
After shipping for the socket and seat, it was $27 from marlin. A new dealer seat was about $13 (I didn't check on the price of the socket, because I didn't need one) I wound up selling the marlin socket and seat. I just think that the $13 OEM one lasted for 15 years and 140k miles (it was still in one piece, just starting to crack), so another OEM should last the same.
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
GorgeRunner
Jun 27, 2015 07:01 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
mytruck
25
Jul 15, 2002 04:28 AM
Krash
10
Jul 13, 2002 09:21 PM
