My dipstick tube won't stay in the block
Old Dec 23, 2009 | 05:42 PM
broncrider's Avatar
well good news is that i got my toyota going tonight after several months of sitting. mainly to being busy as hell at work. but got the oil leak fixed from the oil pan. got it all timed up then out around the shop. made a couple laps and pulled it in to check. of course like any project had another problem. just a clamp left off a water hose. well thought it was all good so went and drove it around for a while. still around the shop. pulled back in and my dip stick has come out and doesnt go back in to its place and stay. need any ideas on how to fix this problem. sorry just new to toyota's.. o ya did get a chance to try the 4wd and had to climp are dirt pile hahaha
Old Dec 23, 2009 | 06:06 PM
broncrider's Avatar
come on guys someone has to have a fix it idea
Old Dec 23, 2009 | 06:11 PM
rattlewagon's Avatar
gotta give people more than an hour to respond. im a little unclear on the current problem. is the dip stick not going back into the tube? is that the problem? have you tried turning it? again, not sure of the issue.
Old Dec 23, 2009 | 06:14 PM
broncrider's Avatar
the dip stick tube doesnt stay in the block. sorry i wasnt clear.
Old Dec 23, 2009 | 06:51 PM
thedanned's Avatar
Im guessing 22re because you said timing chain, right? I dont have any experience with the r motor, but on a lot of engines I have worked on the dipstick tube has a bracket that bolts to the block. Is it something as simple as that?
Old Dec 23, 2009 | 06:55 PM
abecedarian's Avatar
did you put the bolt through the tab on the tube which secures it to the engine block?
Old Dec 23, 2009 | 07:00 PM
87topless's Avatar
I had the same problem after the rebuild (22RE). No bracket on the tube. I opened up/stretched/enlarged/expanded the end of the tube slightly to create more friction between the tube and block, and hammered it in place. So far so good.
Old Dec 23, 2009 | 07:20 PM
broncrider's Avatar
ok guys thanks didnt have time to really. but tomorrow i will. thanks guys
dumpster84
Apr 30, 2016 06:03 AM
shisha1999
Sep 21, 2015 08:22 PM
ViperTT
Aug 14, 2015 05:27 AM
trucker trash
Jul 28, 2015 10:09 AM
adammtb
Jul 27, 2015 11:57 AM
