My 86 Turbo 4Runner Dilemma
I have an 86 turbo 4Runner with 186000 mi. running fairly well right now. The problem is, I have leaks in the rear main engine seal and the timing cover as well as the oil pan. I am also burning oil in two of my cylinders. The dealer wants over $3000 to make this all right (LOL) Do I rebuild?? Do I drop in remanufactured?? Could I drop in a standard 22re. For now I will just drive it but what are some of your thoughts and opinions on what I should do????
Don't worry taking it to the dealer is not an option:pat:
My friend bought one, and it needed help and he swapped in a 22r. I ended up buying it from him and aside from some OTHER issues, it seems to be fine. I even considered looking for a diesel and trying to make a bio-diesel turbo 4runner.
22rs can be had for around 1k under 2k for sure. My advice, hold onto the manifold and turbo if you can, and one day try and rebuild it. My friend when he did it, was poor and ended up trading w/ a Toyota guy here in town (specializes in nothing but Toyotas) and getting some of the parts he needed.
22r is solid and reliable for sure. I'd love to put another turbo motor in it at some point.
MOmo
MOmo
Rear main seal is much harder, as it requires transmission to be pulled (do it when you do the oil pan, as the pan has to come off too).
Why do you think you need a rebuild? You need to do a compression test OR a leak down test. Post the results. You may just have the oil leak blues!
Only other item I'd recommend is a new timing chain and guides. This could be done if you fix the front timing cover.
I've got a 22RE that had over 200k on it. It had 162-164 psi on all 4 cylinders.. With a good timing chain, no reason why it wouldn't make it to 250 or 300k.
You can't drop in a standard 22RE without replacing the ECU also... Ideally you'd use the 22RE wiring harness, as it actually supports more signals than the 22RTE version. It's not a small job.
I don't know if you can actually get a reman'd 22RTE.. Rebuild wise, it shouldn't cost much more - if any more than a standard 22RE.
I don't dismiss the toyota tech's experience at all.. I just think that you guys should get paid better. However, you don't know who is working on the vehicle - it the job of the "service advisor" to provide a barrier... I mean interface with the customer..
The #1 thing that irks me about mechanics:
Guessing with my money in regard to fixing an issue.
If you don't know what it is, say so... Don't replace part A, replace part B, replace part C, replace part D until you get it right...
Course, part D was the problem. A-C were just collateral damage to the wallet.
and we can "try components" to confirm a problem component from a donor vehicle. Someting most independent shops cant. Much easier on the wallet as we replace only whats wrong. If we dont fix it, you dont pay for it and you dont pay for anything it doesnt need. Now if you have a runnability problem, have plugs that are so worn out and the gap is .120" of an inch, we like to replace items like that to eliminate an area that could easily be the problem, but if it turns out not to be the problem, its not like they werent needed anyway. If you avoid the obvious like this, you can spend a bunch of time looking elsewhere, when this was the problem all along.
