more tranny problems
Old Apr 14, 2009 | 09:18 AM
j0hNnI's Avatar
new clutch pressure plate throwout bearing an pilot bearing an clutchfork
went mudding yesterday an now i cant shift into third gear unless i slam it into the gear any insight of what this could be personally i think its the syncros
Old Apr 14, 2009 | 10:53 AM
desertcox05's Avatar
bent shift fork.. if it was synchros- you could it if you let the rpm's drop and pull it into gear, or turn the truck off and put it in gear.
Old Apr 16, 2009 | 06:18 AM
j0hNnI's Avatar
i can turn the truck off an put in into gear
Old Apr 16, 2009 | 06:53 AM
PlugItIn's Avatar
can you do it easily when its off, or is still hard? Desert was right on the syncro's part if you can do it while its off or when dropping the rpms down
Old Apr 16, 2009 | 07:07 AM
lilgreg46's Avatar
When is the last time you replaced the bushings under the shifter? I know it will take a lot of slop out of the shifter and might be part of your problem. Just my teo cents.. The sight is for upgraded bushings http://www.marlincrawler.com/catalog/70/parts_upgrades
Good luck!
Old Apr 16, 2009 | 09:27 AM
j0hNnI's Avatar
i just got this truck a couple months ago not really sure on anything that has been replaced before an something in my transmission is also screaming at me sounds like a constant grinding i replaced pilot bear clutch fork pressure plate flywheel clutch an it removed the problem for a little bit but if i shifted fast enough i would still grind into 3rd 4th an 5th
Old Apr 16, 2009 | 09:59 AM
PlugItIn's Avatar
how many miles are on that tranny? That grinding usually means syncros are going bye bye. Thats a lot of syncros to go bad at once though, but it can happen if the previous owner was a crappy driver
Dieselmann
Feb 19, 2019 02:57 AM
shadowbirdie
Jul 21, 2015 10:38 PM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
Jnkml
Jul 6, 2015 01:20 PM
