Mods for the 3.0 durring a full rebuild
Old Nov 13, 2008 | 10:48 AM
  #261
ddiablo's Avatar
no come on the story can't end this way. dont let it die after all the effort plz!!
Old Nov 15, 2008 | 09:32 PM
  #262
4runnerguy's Avatar
what to this thread i was looking forward to this on seeing how it worked
Old Nov 16, 2008 | 09:54 AM
  #263
76ANTHONY's Avatar
i think it ends with, he ran out of money and no time for the 3.0.
Old Nov 18, 2008 | 05:33 PM
  #264
4runnerguy's Avatar
i would love to try this out but got no job who would be willing to try
Old Nov 18, 2008 | 06:25 PM
  #265
4runnerguy's Avatar
any one willing to try
Old Nov 18, 2008 | 06:53 PM
  #266
Matt16's Avatar
Originally Posted by Dan_90SR5
Alright, I could sit and read all the good and bad that everyone is writting and posting links about the 3VZ-E that came in the 4Runners and Trucks. But have a real answer for you and it's the current project that I'm working on that is taking alot longer due to lack of work and as a result funds.
Here is what needs to be done to give yourself a good basis to get more HP than a stock 5VZ-FE.
1. Get a rebuild kit for a 3VZ-FE engine pistons too, though they usually come with the kits. (92-93 Camry)
2. Get heads w/ignition and valve covers from the above engine. (DOHC) you can pick up used heads in good condition for $75 ea. if you shop around. Rebuild them. Or you can buy rebuilt heads from TAP Recycling for $450 ea.
3. Get the entire intake plenem (3 pieces) and TB from a 3rd gen. 4Runner/Taco. Yhis is needed to bolt to your new heads.
4. Have headers made or fab them yourself if you have the means. Dual 2 1/2" exhaust or single 3".
Then if you want, you can do all of the porting and polishing and all of the other stuff that people are recommending.
I've been hesitant about talking about this, wanting to be the first to finish mine, but if you're in the process and want to know what I'm doing, there it is. This all bolts right up since they are essentially the same block. If you know the engine codes and have worked with Toyotas enough you'd be surprised what all will change over. The Celica owners out there know all about head swaps with Toyotas.
You might ask the reason for the intake from a 5VZ and not the stock intake or one from the 3ZV-FE, and here is the answer. The stock intake....the lower part that bolts to the heads is now too wide for the new larger heads and the upper part will not bolt to the lower of the 3VZ-FE or 5VZ-FE. The 3VZ-FE intake will work, but will face your firewall, which isn't good (have to thing how it was mounted in the Camry). So the 5VZ-FE being a RWD/4WD application will make it face the right direction.
I could make this post insanely long with all of the info that I have about these engines and Toyota engines in general, but I won't. If you have anymore questions feel free to reply to this or message me.
Great post! I don't even own a 3vze and I enjoyed reading it.
Old Dec 8, 2008 | 07:16 AM
  #267
EvergreenToy's Avatar
Damn. This is all good stuff. I'm still learning alot about these engines and the persistent bashing of the 3.0 feeds the flame to make it better. Anyone seen a throttle body spacer for this one? Not sure if it would be a great idea or not but perhaps a small improvement.
Also, no one brings into consideration the longevity of these engines. 2nd gen runners are still all over the place. Mine has over 200k on the odometer and is still running strong. Just an aside.
Old Apr 1, 2009 | 10:25 PM
  #268
sinneDBTB's Avatar
Originally Posted by h7009
take a razor blade and cut the seal on the air mass sensor, pull open, gently with a knife blade. You will see what looks like a ring in a military compass, there is a arm holding the ring tight. Mark where the arm hits the ring and there back the ring counter clock wise three(3) notchs. This will allow the mass air sensor to open quicker and allow more air to enter the truck, you will notice a difference
anyone know if this works?
Old Apr 1, 2009 | 10:43 PM
  #269
mrddk92's Avatar
idk if that works but soon i will put in weasy cams, lce headers, o/s valves and some portin and polishin ill post what i think afterwards
Old Apr 2, 2009 | 03:22 AM
  #270
TNRabbit's Avatar
Originally Posted by [B
h7009[/B]
It fools the ECU into thinking more air is being passed and richens the mixture. It does NOT open the VAFM (not MAF) quicker. Most people report worse mileage and negligible power difference unless your do something to the engine that requires it to run richer.
Old Apr 24, 2009 | 07:22 PM
  #271
Texas91Runner's Avatar
I wanna know more! I'm close to the point where I may be doing this exact swap..
Old Dec 13, 2009 | 11:21 PM
  #272
Tracey98277's Avatar
i can't believe this thread died... so sad... i bet it would have been a good franken-motor. i put rebuilt heads, crower cams, and headers on my 3.0 and the only time i really feel an increase in power is when i use nitrous lol. (yes for real... let the NOS bashing begin...)
Old Feb 18, 2010 | 01:11 AM
  #273
just call me smithy's Avatar
so what ever hapend to dan? did the 3.0 get any better?
Old Feb 18, 2010 | 11:55 AM
  #274
dose any one know what happened to this project? it seamed promising
Old Feb 18, 2010 | 12:15 PM
  #275
camo31_10.50's Avatar
lol run the 3vz-fe, 3vze, 5vz-fe franken motor LOL
Old Feb 18, 2010 | 12:34 PM
  #276
mrddk92's Avatar
Lol I did a bit to my 3vze and I regret it. Save your money for a swap. I'm saving for a 1uzfe lol.
Old Aug 10, 2010 | 05:05 PM
  #277
bigap81v's Avatar
what gaskets were used for all this.... very interested to revive the 3.slows rep
tired of gettin about it
Old Nov 23, 2012 | 06:02 PM
  #278
Asuarez737's Avatar
can someone please help me!!! i know this thread is dead, but hopefully someone on this thread still logs on!
https://www.yotatech.com/forums/f116/3vz-e-help-261724/
Old Jan 9, 2013 | 03:11 PM
  #279
ROCKLAND TOYOTA's Avatar
Im new to forum But not to toyota's. i work at a dealer in NY and picked up a 95 v6 runner with a bad rod knock that eventually put a hole in block the size of a grapefruit. Besides the hole it also broke starter into about 10 pieces as well as taking out oil pan and its baffle. I decided to forgo gettting another used engine seeing as none i could find were under 100K and went with the toyota parts catalog . NEW toyota short block and heads as well as anything and mostly everything else that was needed to put engine back together from scratch. i will have pictures up soon as engine is sitting on the stand as my prep department is cleaning up engine bay to complete my showroom looking engine bay.
got a ??? just ask me......
Old Jan 10, 2013 | 03:14 PM
  #280
astynx's Avatar
Mr. Rockland Toyota, Can't wait to see the pictures. Also I might go this route some day with Toyota OEM engine replacement. I'm concerned about the expense though. Thanks.
