Master Cylinder?
Old Sep 27, 2006 | 09:49 PM
MikeKaduce's Avatar
Master Cylinder?
My brake fluid reservoir won't hold fluid and my brakes have degenerated into pretty much nothing, goes all the way to the floor. Pretty sure its a master cylinder replacement, how much will that run me and is it a pretty easy job to do myself? I have an 88 Toy p/u 22re.
Old Sep 27, 2006 | 10:32 PM
bob200587's Avatar
Not sure on the price. But DO NOT buy aftermarket. go get the genuine toyota parts. I won't go into the experiences I've had with crappy parts from the general auto stores.
I suggest you get the one man bleeder screws though. It's 10 bucks for 2 so you'll spend 20, but it's worth it. They have a check valve that makes it a one man job. You open the valve just a 1/4-1/2 turn, pump the pedal and it should pressurize. I have one on my clutch master. well worth the money.
Old Sep 28, 2006 | 03:56 AM
dcg9381's Avatar
IT could be the slave.. Where's it leaking from?
It's an easy job - just learn to bleed the brakes.
+1 on using toyota parts.. unless you like doing the job again.
Old Sep 28, 2006 | 05:19 AM
AlaskaToy's Avatar
I have a used one (master cylinder, genuine OE Toyota/Asin) from my 93 V6 4x4. worked just fine when I pulled it as part of my axle swap. $40 shipped to 48 states.
Old Sep 28, 2006 | 05:58 AM
toyaholic's Avatar
those 90's model master cylinders are different than the 80's models. mine was leaking from the reservior and i replaced the gasket that sits between the reservoir and the master cylinder and it is nice and tight now, no leaks. got the gasket from toyota. i let mine leak down while i was rebuilding my engine and test drove it while it was low on fluid and now i have to bleed the system.
4.34runner88
Feb 7, 2016 02:24 AM
scheuvront1993
Sep 17, 2015 06:17 PM
user 82300
Sep 15, 2015 05:49 AM
old87yota
Sep 9, 2015 12:39 PM
Squigglez
Sep 4, 2015 07:33 AM
