Mass load of parts replaced, still no start
Old Nov 15, 2011 | 09:06 AM
  #101
xxxtreme22r's Avatar
Just because it's a new fuel pump, doesn't mean the ecu or other components are operating that properly. This is why I had asked did you attempt to run it with the jumper installed.
Old Nov 15, 2011 | 09:10 AM
  #102
02/89yota's Avatar
if you're asking if I ran the truck with the fuel pump jumped, then, no.
Old Nov 15, 2011 | 09:13 AM
  #103
Did you attempt to start it with it jumped?
Old Nov 15, 2011 | 09:58 AM
  #104
02/89yota's Avatar
no, i have not
Old Nov 15, 2011 | 11:38 AM
  #105
radrace2001's Avatar
have you tried removing the cat and running the truck? it could have been partially blocked before and now is totally blocked keeping it from running.
Old Nov 15, 2011 | 12:09 PM
  #106
VegasNaturist's Avatar
Okay, I only scanned the thread so I might have missed something, but I'll relate an issue I had with my 22 as advisement.
My truck was running fine, then developed a slight miss. Miss turned into barely running, finally truck dies and would not run. I had just replaced the injectors with reman's so I dismissed them as a cause. Turns out after weeks of head scratching and part$, my injectors were plugged solid.
I had filled the truck with fuel at a newly opened gas station and suspect I got a load of dirty fuel. When I found the injectors plugged, I cut my fuel filter open and found it was packed with fine powdery dirt. Same dirt I found clogging the injectors! The filter was only about 2000 miles old, but it was a cheap Autozone filter. I suspect bad (dirty) fuel plugged the filter, but the pump overpowered the filter causing it to burst internally and send the silt to the injectors and plug them up solid. I cleaned the fuel rail, drained and flushed the tank and lines, and replaced the injectors again. problem solved.
I might suggest you pull the injectors and have them professionally reman'ed. I understand witchhunter is good at this. (I used injectorwarehouse and they actually warrantied the injectors even though it wasn't their fault).
edited to add: To me it sounds like fuel starvation. Even though your fuel pump is putting out the correct pressures, the fuel might not be getting past the injectors...
Just sayin...
John
Old Nov 15, 2011 | 05:24 PM
  #107
02/89yota's Avatar
John, thanks for that, how do I test Injectors to see if they're clogged..
Also, anyone know how to test a distributor?
Old Nov 15, 2011 | 06:47 PM
  #108
92dlxman's Avatar
test a distributor for what? shaft end play?
i reckon you havnt replaced your cap, rotor, wires, etc. im re-visiting this post to see if you made any progress. you havent. you've gone backwards.
your waiting for a magic answer. its not there, the best thing to do, is READ. quit asking and just READ. as i said before, BUY A BOOK! HAYNES, CHILTON, TOYOTA i dont care! the questions you ask are silly and irrelevent because you are UN-EDUCATED IN THE PROPER WORKINGS OF THE 22RE AND ITS ACCESSORIES. LEARN FIRST, ASK SECOND.
ALSO, WHEN SOMEONE SAYS TO TRY SOMETHING, AND IT SOUNDS LOGICAL, TRY IT. IT MIGHT FIX YOUR TRUCK. YOU HAVE NO IDEA WHERE YOUR TIMING IS SET. I BET YOUR TPS IS INCORRECTLY ADJUSTED, AND A VOICE JUST TOLD ME THAT YOURE INTIRE TRUCK IS ASS BACKWARDS IF YOU'VE BEEN WRENCHING ON IT FOR 5 YEARS.
TNRABBIT SOUNDS TO ME LIKE YOUR BEST SHOT. EGR. THE BOOK YOU BOUGHT WILL PROPERLY EXPLAIN HOW TO TEST.
UNTILL YOUR NEXT COMPLAINT: GOOD DAY
Old Nov 15, 2011 | 07:04 PM
  #109
02/89yota's Avatar
Someone pissed in his cheerios this morning.
I HAVE A BOOK AND USE.IT FREQUENTLY. Care to see? Before being an ass, make sure you have all facts.. Thanks.
Old Nov 16, 2011 | 10:19 AM
  #110
The only difinitive way to tell if they are actually plugged is to pull them out and look at them. You can check for power using a noid light, and/or you can use an automotive stethiscope to listen for a crisp click, but that may not tell the whole story. There is a very fine mesh screen at the inlet of the injector. They tend to get gunked up easily over the years. Best practice would be to pull them and send them out to be cleaned.
To answer your other question, ohm out the pick-up coil in the distributer and compare your readings with the FSM. Out of spec? replace. Cap and rotor just get replaced. They're cheap enough.
John
Old Nov 17, 2011 | 06:42 AM
  #111
02/89yota's Avatar
John thanks for that, I am going to start the tear down now
Old Nov 18, 2011 | 06:19 PM
  #112
02/89yota's Avatar
Put BRAND NEW OEM injectors into this piece, and still not working......
Old Nov 19, 2011 | 04:02 AM
  #113
Once again, what dose the fuel jumper do when you put it in? What is your timing set at? And if you don't have a multimeter, I highly doubt your TPS is adjusted correctly.
Only thing in the distributor you can check is the air gap which isn't correctable. How have you checked too see if you have spark? By replacing plug wires, cap and rotor? How have you checked to see if you have fuel? By replacing the fuel pump and fuel filter? Your throwing parts at this thing and not testing ANYTHING. If you are, you aren't coming back here with your results.
Which book are you using? A haynes? A Chiltons? Both SUCK. Get yourself an FSM they are free and 100% better then those two stupid books.
Old Nov 19, 2011 | 10:36 PM
  #114
Take the cat off the truck and respond with results please. This check will not cost you anything but maybe a half hour of your time. It will not hurt to try it.
Old Nov 20, 2011 | 12:41 PM
  #115
02/89yota's Avatar
Timing is set to 5btdc, I am gunna roll it in the garage and pull the cat off and see what that does
Old Nov 20, 2011 | 12:52 PM
  #116
5btdc with the jumper right?
Old Nov 20, 2011 | 01:04 PM
  #117
02/89yota's Avatar
Ok pulled the cat, no start, put it back on, nothing, made sure the tps sensor was correctly positioned, with the multimeter etc, ran for a bit, then died, now wont restart
Old Nov 20, 2011 | 04:40 PM
  #118
sorry bad post
Old Nov 20, 2011 | 09:33 PM
  #119
thank you for the response. i am sorry it did not help. it might be in the higher rpm's for that problem. have you checked all the grounds on the motor especially the one on the intake? you might have a bad connection there. it controls your injectors add other sensors i believe. you can try cleaning it and making sure the bolt is tight.
Attached Thumbnails Mass load of parts replaced, still no start-22regroundstrap002.jpg
Old Nov 21, 2011 | 11:22 AM
  #120
Sorry this didn't help, but dude, you didn't need to spend that much $!, www.witchhunter.com would have done it for less than a c-note including shipping...
John
