LSVP height
LSVP height
i have downey HD 1.5" springs, and want to get a 2" spacer...
should i use the top or middle holes on my LSVP bracket that came with the downey kit.
Currenly i have 1" spacer and am using the middle bracket...and my panhard is dead level.
cheers
cheers
hey hill!
you seem to be talking about two different parts, lsvp and pan hard rod. all i can suggest is put in the spacers and check both lsvp and p/h, you may have to use the upper mounting hole to keep things in the same place as they are now.
lee
lee
Your panhard has nothing to do with your LSPV (Load Sensing Proportioning Valve). You are correct in using the middle hole right now. When you add the coils and a spacer, you will need to use the bottom (or top) hole (don't remember which, just not the middle hole).
Hope that helps.
Hope that helps.
No problem, I've Been There and Dont That with the LSPV. When I ran into it, nobody seemed to know what it was or how it worked. My 3.5" lift kit came with a 2" bracket and I finally convinced myself that that was just not right:
- http://www.4crawler.com/4x4/4R_suspe...ortioningValve
live4soccer7
May 11, 2016 06:52 PM
ktm192k
Sep 24, 2015 03:36 PM
justdifferentials
Sep 5, 2015 06:52 PM
