Lowering Compression
Old Sep 8, 2010 | 05:06 AM
saitotiktmdog's Avatar
I am already running 7 psi as a maximum. Not sure howmuch power and torque as I have never had it on a dyno. My estimate would be maybe 165, 170. But I really have no Idea. I know it has a ton more than it ever did before the turbo.
Old Sep 8, 2010 | 06:23 AM
greatskiiiier's Avatar
my 22rte is stock with air box mod, !cat and flowmaster and it does fine with 33s, makes 3psi under any load at all, under a good load more than 1/4 throttle it boosts to 5psi and under heavy throttle/ load it boosts to 6psi but the a/f drops to ~10:1
i've hit 8psi under WOT but the a/f ratio was well below 10:1
i plan to put a manual boost controller in it so ill be making 8psi when im currently making 5psi so ill max out at ~10psi since i NEVER go WOT
Old Sep 8, 2010 | 06:38 AM
I have a boost controller but I cant really use it. It came with my external wastegate. I have hit ten as well and my af is below 10:1 as well and my ignition retards to below 18 degrees before tdc. I also have a knock sensor that will take more timing out if need be. I am able to set how much ignition timing there is as well as how is taken out for boost etc. With this setup It runs well and I am not worried about blowing it up all the time. I dont stay in it tool ong however as timing less than 18 for too long means a huge egt spike.
Old Sep 8, 2010 | 12:20 PM
Flash319's Avatar
So right now you are running 7psi on stock compression? 94 octane? Nice . I wanna play..................
Old Sep 8, 2010 | 12:25 PM
  #25
Pretty much except on 93 octane as thats best I can find around here.
Old Sep 8, 2010 | 12:47 PM
  #26
Flash319's Avatar
Sorry for the slight hi-jack but just 3 more questions.
What are you using for an airflow meter?
What T3 are you using and whats the A/F of it?
Where is the torque (RPM wise) with your setup?
I'm done
Old Sep 9, 2010 | 05:21 AM
  #27
I'm done
I use a map sensor not an AFM. Honestly I am not sure what the specs of the turbine and compressor are on my turbo. I have quite a bit of torque it pulls really well throughout. Because I currently have higher compression there is really no lag before power starts. But if I had to guess I would say 2000 - 4500 is where it pulls best. as long as your not trying to excellerate quickly at 2000 rpms in fifth gear.
alexcarey
Oct 14, 2015 06:05 PM
moparbay
Oct 6, 2015 09:24 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
voiddweller
Sep 28, 2015 11:21 PM
JRB4Runner2015
Sep 20, 2015 12:29 AM
