Lower Ball Joint
Old Jul 7, 2012 | 10:59 PM
pjmags's Avatar
Lower Ball Joint
My front passenger side lower ball joint is shot. Any reccomendations on what type of ball joint i should purchase? Any particular brand? Greaseable or non-greaseable? Thanks!
Old Jul 8, 2012 | 02:10 AM
cambob's Avatar
Order the Beck Arnley ones on amazon. Like 30 or so a piece. I just ordered some a couple weeks ago and inside the box were Sankei (555) joints. Basically short of Toyota, I think its as good as you can get. Also, they are grease able.
Old Jul 8, 2012 | 04:09 PM
slow-mo's Avatar
The Moog upper & lower ball joints I bought at Rockauto are also stamped 555 & say "Made In Japan"
Old Jul 8, 2012 | 04:12 PM
slow-mo's Avatar
The Moog upper & lower ball joints I bought at Rockauto are also stamped 555 & say "Made In Japan" They come with grease fittings in the bag but as the sit in the sealed plastic bag there is a bolt in that spot just like the OEM ball joints are on the truck.
D'oh...double post. I didn't see a way to delete the first one.
Old Jul 8, 2012 | 05:07 PM
cred92's Avatar
Just ordered a set of uppers and lowers from MOOG k9519 lower and k9482 upper from rockauto. Best pricing anywhere bout 42$ a piece n cheap shipping like 10$
Old Jul 8, 2012 | 09:20 PM
abecedarian's Avatar
Greasable are the best bet, and if they come with a bolt in place of the zerk fitting, that's just so you can remove the zerk after greasing. Put the zerk in, grease, pull the zerk and replace with the bolt- then nothing to break off on the trails.
Old Jul 9, 2012 | 05:15 PM
gottadog's Avatar
Lowers at autozone were the sankei 555's. Cheap too.
aowRS
Sep 13, 2017 08:22 AM
Odin
Sep 24, 2015 04:38 AM
JRB4Runner2015
Sep 20, 2015 12:29 AM
Regency
Sep 6, 2015 05:47 PM
