Low Fuel Gauge
Old Feb 7, 2020 | 09:27 PM
Co_94_PU's Avatar
You know that point when you turn the key from off->acc->run and the dash lights up "bulb check" .. If it doesn't come on then it's not going to come on and warn you later. ;-) you either don't have a bulb, don't have a wire or don't have a sender.
Old Feb 8, 2020 | 02:24 AM
wallytoo's Avatar
Originally Posted by keycw
I forgot they even had one. I remember my 88 dlx light used to come on but my 87 sr5 that I drive now, ive never seen the light and im sure ive had it down far enough, maybe I need to test this.
the one in my “older” ‘87 works. it was on for much of the day. when i filled up yesterday, put 17.2 gallons in the tank. i almost always run the tank until the light comes on.
Old Feb 8, 2020 | 02:30 AM
wallytoo's Avatar
perhaps on the later trucks; most assuredly not the case for 1st gen 4runners. my low fuel light is fully operational. it does not light up on initial key on sequence when other gauge lights come on. ever.
Old Feb 8, 2020 | 04:53 AM
Co_94_PU's Avatar
Just rubbit in, I haven't been able to drive mine.. Short memory fun
Old Feb 8, 2020 | 06:58 AM
  #25
Paul22RE's Avatar
5 Year Member
Originally Posted by N_Aviles
ok, 20 year plus years of Toyota/Lexus parts guy experience here. If you look up North American built trucks, they were all deluxe models hence the same part number. If you look up Japanese built trucks from the same generation you will see the VZN110 SR5 has its own gauge sender part number. The Japanese built deluxe all have same sender as the NAP trucks.
Thanks, I think I finally found the part number for an SR5 (83320-80178)here: https://www.toyotapartsdeal.com/oem-...-JPP&Filter=() Says discontinued.
Old Feb 8, 2020 | 07:34 AM
  #26
GeoRoss's Avatar
my truck is a 22re deluxe with the factory upgrade tach gauge cluster. The bulb is in there but I’ve never seen it come on. I can’t answer for sure what sender my truck has. I know for sure it is the one it left the factory with.
My original DLX cluster did not have a low fuel light in it, but it did have a three wire sender and wiring for that light to the cluster.
I’d look at the wiring going to the sender. If it has three wires going into the sender and three at the harness you likely have the wiring. I would do the FSM check to see if the light comes on if you have the three wire sender.
If the cluster light doesn’t come on with the FSM procedure, I would then pull the cluster and check the bulb directly. If the bulb is good, I would then check the cluster for continuity and see if I could get the bulb to come on by applying voltage and ground to the appropriate pins on the cluster. If that works I would check for continuity of the harness wiring.
If if you don’t have a three wire sender you are looking at dropping the tank and putting in an appropriate three wire sender and running a wire to the cluster.
Old Feb 8, 2020 | 09:41 AM
  #27
N_Aviles's Avatar
Originally Posted by Paul22RE
..... I just ended up using that light as an indicator that I have my fog lights on.
not to go off topic, but I just thought about this. I added some foglamps to my truck and used this OEM Toyota accessory fog lamp switch. It has an indicator light built in. It was like $8.
ok like $15 I guess
https://www.googleadservices.com/pag...BAgJECU&adurl=
Old Feb 8, 2020 | 04:17 PM
  #28
wallytoo's Avatar
not rubbing it in; just glad i get to daily my red ‘87 and have the white ‘87 too. i thoroughly enjoy driving these.
Old Feb 8, 2020 | 08:08 PM
  #29
2ToyGuy's Avatar
Now, you just need a Blue 87!
Very patriotic
Pat☺
foppert
May 7, 2017 09:02 AM
little_93_pickup
Oct 5, 2011 05:47 PM
clonman123
Jul 10, 2011 11:39 AM
dboatrig
Jul 14, 2009 10:11 AM
artofliphkd
Feb 14, 2008 11:32 AM
