Loss of power then it comes back to life
Old Jan 4, 2007 | 09:10 AM
Myron's Avatar
Heres the deal, If i hit the gas it takes a few seconds to accelerate then all of a sudden it gets all its power back..do i have a leak some where or whats going on?
Old Jan 4, 2007 | 09:21 AM
Tacoclimber's Avatar
Perhaps a clogged fuel filter?
Old Jan 4, 2007 | 11:29 AM
Bear80's Avatar
how is it when you crank it cold? Does it stumble?
Old Jan 4, 2007 | 11:47 AM
misterzee's Avatar
is it running smoothly even when it is trying to find its power? if its rough, and then smooths out, its probably a plug, or wire, or cap, or injector.
Old Jan 4, 2007 | 02:18 PM
Myron's Avatar
It kinda stumbles on on start up (caold) then its fine, but when i accelerate it goes then looses power then shoots rite back up with power...
Old Jan 4, 2007 | 09:14 PM
Bear80's Avatar
if it stumbles on cold start up, and a loss of power it could be your fuel pressure regulator.
Old Jan 5, 2007 | 05:57 AM
rdlsz24's Avatar
Check the plug-in on your cold start injector temp sensor. I had the same problem when mine came unplugged.
It's the green plug in the red box in this pic:
Rob
Old Jan 5, 2007 | 06:26 AM
all_terrain17's Avatar
I kinda get the same problem sometimes on warm start up. Way down on power for about a minute it seems...then it's fine
Old Jan 5, 2007 | 09:15 PM
pruney81's Avatar
I have the exact same problem on my 95 3.0, it just started a two days ago. First cold start in the mornings it stumbles, and if I hit the gas while driving it hesitates for a few seconds then kicks back on like normal. This could be the fuel pressure regulator? Where is that?
Old Apr 25, 2011 | 01:39 PM
jrod1407's Avatar
having the same problem on my 1990 v6 two door 4runner. it's not a huge problem but definitely annoying hopefully someone can figure it out.
Old Apr 25, 2011 | 02:47 PM
jrobertson4runnner's Avatar
I would say check the fuel filter. My '91 3.0 did that for awhile, and then it got to the point where it wouldn't start. new fuel filter, and presto, she ran again.... then died on me 6 months later. thrust bearings were bad, and a whole lot else too. My Dad's '90 3.0 is doing that now, just been too lazy/busy to change the filter. May also be the regulator, so check that too.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
karbin
Jul 5, 2015 11:37 PM
elwood73
Jul 5, 2015 07:07 AM
