Loss of power then it comes back to life
Old 01-04-2007, 09:10 AM
Myron's Avatar
Heres the deal, If i hit the gas it takes a few seconds to accelerate then all of a sudden it gets all its power back..do i have a leak some where or whats going on?
Old 01-04-2007, 09:21 AM
Tacoclimber's Avatar
Perhaps a clogged fuel filter?
Old 01-04-2007, 11:29 AM
Bear80's Avatar
how is it when you crank it cold? Does it stumble?
Old 01-04-2007, 11:47 AM
misterzee's Avatar
is it running smoothly even when it is trying to find its power? if its rough, and then smooths out, its probably a plug, or wire, or cap, or injector.
Old 01-04-2007, 02:18 PM
Myron's Avatar
It kinda stumbles on on start up (caold) then its fine, but when i accelerate it goes then looses power then shoots rite back up with power...
Old 01-04-2007, 09:14 PM
Bear80's Avatar
if it stumbles on cold start up, and a loss of power it could be your fuel pressure regulator.
Old 01-05-2007, 05:57 AM
rdlsz24's Avatar
Check the plug-in on your cold start injector temp sensor. I had the same problem when mine came unplugged.
It's the green plug in the red box in this pic:
Rob
Old 01-05-2007, 06:26 AM
all_terrain17's Avatar
I kinda get the same problem sometimes on warm start up. Way down on power for about a minute it seems...then it's fine
Old 01-05-2007, 09:15 PM
pruney81's Avatar
I have the exact same problem on my 95 3.0, it just started a two days ago. First cold start in the mornings it stumbles, and if I hit the gas while driving it hesitates for a few seconds then kicks back on like normal. This could be the fuel pressure regulator? Where is that?
Old 04-25-2011, 01:39 PM
jrod1407's Avatar
having the same problem on my 1990 v6 two door 4runner. it's not a huge problem but definitely annoying hopefully someone can figure it out.
Old 04-25-2011, 02:47 PM
jrobertson4runnner's Avatar
I would say check the fuel filter. My '91 3.0 did that for awhile, and then it got to the point where it wouldn't start. new fuel filter, and presto, she ran again.... then died on me 6 months later. thrust bearings were bad, and a whole lot else too. My Dad's '90 3.0 is doing that now, just been too lazy/busy to change the filter. May also be the regulator, so check that too.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
God's Bounty Hunter
07-08-2015 12:54 PM
karbin
07-05-2015 11:37 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: Loss of power then it comes back to life
