losing a little oil after HG work
Old May 30, 2006 | 06:58 PM
RustBucket's Avatar
The old head had alot wrong with it, so the lower end is now experience new-engine compression, and I think that is what's causing me to lose oil. Every 500 miles or so it's about a quart low. No drips, ever, can't see it burning or smell it, but I have been told that my exhaust has the slightest blue haze to it.
Sound like the rings are just worn out? This is a 210k mile engine.
I think I'm just gonna hold out another 6 months till I can do a rebuild. Has anyone had luck with some STP stuff or something to reduce oil consumption?
Old May 30, 2006 | 07:10 PM
snap-on's Avatar
you might try some seafoam and see if you cant free up the rings a bit.
Old May 30, 2006 | 07:16 PM
RustBucket's Avatar
You just dump that in the oil and leave it till the regular change time?
Have you had good luck with it?
Old May 30, 2006 | 07:26 PM
Elton's Avatar
no dont dump it the oil now i think it makes it to thin
Old May 30, 2006 | 07:35 PM
trx125's Avatar
You can add to oil, put some in a vacuum line(brake booster line) and in your gas!
Old May 30, 2006 | 07:40 PM
RustBucket's Avatar
really?
Old May 31, 2006 | 01:09 AM
ovrrdrive's Avatar
Sure, it's modern day snake oil. You can even fix a flat by rubbing some of it into the bad tire... !
Just kidding... The folks that believe in it swear by it. Myself I haven't tried it but probably will eventually.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Alaskan91
Sep 21, 2015 04:39 AM
colinmil
Jul 6, 2015 04:03 PM
gog1968
Jun 22, 2015 05:55 AM
