long arm Blazeland and 4 inch ifs lift combined?
Old Dec 19, 2010 | 10:29 AM
BlazeN8's Avatar
I've been posting pictures of the build on my build thread at https://www.yotatech.com/forums/f199...thread-203458/
As far as the Idler Arm you can read about that at https://www.yotatech.com/forums/f31/...spacers-86026/
Old Dec 19, 2010 | 07:25 PM
muddpigg's Avatar
Not that interested thanks. I don't have one so doesn't apply, was just curious. Thanks.
Old Dec 19, 2010 | 08:18 PM
iamsuperbleeder's Avatar
fair enough
are your coil-over lower mounts just the factory shock mounts on the LCA's?
Old Dec 20, 2010 | 07:55 PM
BlazeN8's Avatar
The shock tabs on the LCAs are the factory tabs. When someone goes for a Coil-Over Conversion or a Coil Over Assist then they need to weld on some additional tabs with the correct bolt size and width. If you buy the Blazeland Long Arm kit and the Blazeland Shock Hoop Kit I can position the tabs onto the LCA for you as a special request.
Originally Posted by iamsuperbleeder
fair enough
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
razorman8669
Jul 12, 2015 12:13 PM
akaphilly
Jul 9, 2015 02:34 PM
akaphilly
Jul 9, 2015 02:18 PM
