Like I Need Another Project...
Old Jul 5, 2009 | 01:16 PM
  #61
Tubbyfatty's Avatar
Fail if the tool breaks, win if you get it off haha.
Old Jul 5, 2009 | 01:41 PM
  #62
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Old Jul 5, 2009 | 02:11 PM
  #63
toylocost's Avatar
Fail. Ok. Lets try again.
Fail or win?
Old Jul 5, 2009 | 02:31 PM
  #64
toylocost's Avatar
WlN!!!
Old Jul 5, 2009 | 06:52 PM
  #65
bigtrucknwheels's Avatar
Originally Posted by toylocost
WlN!!!
nice work my friend
Old Jul 5, 2009 | 10:02 PM
  #66
toylocost's Avatar
Plugs, kinda sooty. Guess I'll go get some eh?
Cams out...
Lower intake manifold off...
Mmmm, is this bad?
ANNND, drum roll please... heads off...
So I heard that people have found that taking both heads, both exhaust manifolds, and the crossover pipe off all at the same time is easier. So I tried it. It works and I have proof...
This looks tasty...
Old Jul 5, 2009 | 10:19 PM
  #67
vital22re's Avatar
totally a bro
well shoot half the problem was those darn bosch plugs!
you um.. gonna clean the valley there and maybe replace the freaze plugs?
Old Jul 5, 2009 | 10:24 PM
  #68
RobD's Avatar
Wow...what an ugly mess.
Are those gaskets supposed to be egg shaped around the tops of the cylinders?
Sure you don't want to try the 3.4 swap instead?
Old Jul 5, 2009 | 10:25 PM
  #69
Tubbyfatty's Avatar
Nice welds on the SST upgrade lol.
That looks nasty inside lol. for plugs, I hear the NGK v or g powers are perfect. 2.50/3 a piece.
GREAT WORK!
Old Jul 5, 2009 | 10:40 PM
  #70
toylocost's Avatar
Man I dont even know what to do with it.
The gaskets are off in those pictures. lol.
And if the block is screwed I wont even waste my time on the 3.0. Wich will be sweet cuz I'll have a 3.4 but suck because it'll be another year before I get to drive it lol.
GREAT WORK!
Thanks for the weld compliments. I was just trying to get it done not make pretty welds. lol
Thanks I'll look into those. I work at Toyota though so I'll see what we have cuz I get a discount.
Old Jul 5, 2009 | 11:28 PM
  #71
CRafferty's Avatar
Man, that's some good work you've done, but it looks pretty muffed up in there. I second the 3.4 idea. I think if you work with the same diligence you have with the 3.0 so far you'll have it done and running in a weekend! lol
GOOD LUCK!!!
Old Jul 5, 2009 | 11:51 PM
  #72
modlite's Avatar
So for the typical head gasket job do you just put new head gaskets on and put it back together?
Old Jul 6, 2009 | 12:02 AM
  #73
CRafferty's Avatar
I'm not positive because I haven't done one (knocks on wood*) but I think you replace all the gaskets in that area and make sure the block is not cracked due to overheating and then make sure you seal it up all nice and pretty and then put it back together. But wait for other people to answer or SEARCH. It's a pretty extensively covered issue with these 4Runners.
Old Jul 6, 2009 | 12:57 AM
  #74
NicCantDecide's Avatar
All you HAVE to do is replace the headgasket itself, but most people buy a full gasket set and replace everything.
For my Honda you could buy kits: upper engine, lower engine, and complete. I don't know if you can find the same stuff for Toyotas but I'd recommend getting a set of gaskets for the upper half of the engine since its already disassembled.
EDIT: I also recommend copper gasket spray. You spray it on both sides of the head gasket, wait till its tacky, and install it. It'll fill in any small scratches on the mating surfaces and make a better seal. Can't go wrong with it.
Old Jul 6, 2009 | 01:02 AM
  #75
CRafferty's Avatar
I agree. I'm not sure about that gasket spray, I know we used some kind of tacky substance when we were re-gasketing my neighbors Petrol, but idk the name. So some kind of epoxy is a good idea at least.
Old Jul 6, 2009 | 05:57 PM
  #76
toylocost's Avatar
I would but the only thing that is stopping me is money. At least if this is running when I pull it I can get some cash for it.
Honestly, if you do that then your a complete idiot. lol
If that is the ONLY thing that is wrong yes. But if it was over heated you need to have your heads and block resurfaced so that they are flat. They will warp if overheated and wont seal.
Old Jul 6, 2009 | 06:18 PM
  #77
90_2DOOR's Avatar
wow seems to be in awesome condition (exterior & interior) keep us updated!
Old Jul 6, 2009 | 06:20 PM
  #78
toylocost's Avatar
you are obviously not refering to the engine. lol
Old Jul 6, 2009 | 08:57 PM
  #79
toylocost's Avatar
So after my three day weekend I'm back to work with much less time for the truck.
I managed to talk one of the mechanics into letting me borrow this tool for the crank bolt...
Finally got it off. It was more of a PITA sliding the pulley off than getting the bolt out once I had that tool.
Old Jul 6, 2009 | 09:07 PM
  #80
Tubbyfatty's Avatar
Sweet tool lol. Its amazing what tools mechanics have huh?
