Light mounts... But off bumper/roof
Old Aug 19, 2007 | 12:03 PM
AndyL's Avatar
Got a pair of 8" kc's sitting in the back of the 4runner... They really need to get re-mounted...
Bumper doesn't work, the new winch mount doesn't have space, and I have a habit of putting the front bumper into solid objects
Roof's a bad spot, trails we ride are tight, almost ripped the visor off a few times...
Looking for some other ideas, Was looking at the cowl today, not enough depth on the drivers side for the mount.
Anyone found/built an a-pillar mount?
Here's the truck for reference:
Thanks in advance,
Andy
Old Aug 19, 2007 | 12:47 PM
Jay1's Avatar
mount he on the bottom of the front bumper.
Old Aug 19, 2007 | 12:49 PM
95RunnerSR5's Avatar
what about drilling through the top of the fender beside the cowl and infront of the side mirrors
Old Aug 19, 2007 | 01:49 PM
Jay351's Avatar
That sounds like It could work if you position it in such a way not to impeed the hood movement.
Worse comes to worse weld on a tab to bring the lights out a little.
Old Aug 19, 2007 | 02:07 PM
HAVOC's Avatar
http://www.toughstuffproducts.com/pi..._Jeep_Side.jpg
I know it's a Jeep, but is there a way you could have some brackets fabbed up?
Old Aug 19, 2007 | 07:11 PM
AndyL's Avatar
See skid plate damage I'm thinking they'd be a bit low...
Fabbing isn't a problem, was looking for something pre-engineered to copy
Old Aug 19, 2007 | 07:22 PM
olharleyman's Avatar
How about on the hood near the front cornors. Just drill a hole on either side and mount wire them.out of the way and still useible
Old Aug 20, 2007 | 08:31 PM
TurnerR's Avatar
i mounted some hella's on my brothers yj. we just drilled holes through the hood as far back towards the windsheild as we could. just have a buddy hold the one on the drivers side to make sure you can see. with a driving lights you may have a little glare but shouldnt have much of a prob. bein mounted on the hood.. just my 2 cents
Old Aug 20, 2007 | 08:34 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
i fabbed up some mounts out of some metal i had lying around to put them up near my windshield. they bolt in with a factory fender bolt, so no drilling needed. since i put them so far out, though (to allow the hood to open freely), they do jiggle an awful lot over bumps at higher speeds. thicker metal would be good but i was using primitive tools to bend them. there are the only pics i have
Old Aug 20, 2007 | 09:17 PM
drew303's Avatar
^^^^ thats a good idea
sort of like a CB antenna mount but for lights
looks really good
Old Aug 20, 2007 | 09:23 PM
to add to it, the firestik hood channel mounts work just fine for that, but the lights have to be turned sideways to allow the hood open. HaveBlue did it that way with those same lights
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
