Lifted truck, now brakes suck
Old Aug 4, 2011 | 09:11 PM
girlcrazy_4's Avatar
I installed a pair of OME rear coils tonight. Now when I step on the brakes, I really need to stomp them for the truck to stop, where-as before the brakes where super sensitive. Does something need adjusting? I saw the adjuster on the rear diff but no idea how it works... or if it even does. My ABS light is also now on... most likely I pinched a wire.
1992 runner.
Old Aug 4, 2011 | 09:21 PM
anthony1's Avatar
You need to add a bracket for your proportioning valve.
It looks like this...
Just compare your suspension to mine. The pan hard rod is lifted up...You don't need to lift that high. The brass piece above the pan hard bar is what you need....again..not that high. I have way more lift that you do so....
Oh, you may need to extend your brake line as well.
Old Aug 4, 2011 | 09:27 PM
87 Deathtrap's Avatar
The adjuster you saw is most likely your LSPV (load sensing purportioning valve). The LSPV senses the payload in the rear of your truck and automatically adjusts the amount of stopping power applied to the rear brakes to avoid locking up the rear end when the truck is unloaded. By lifting your truck you have most likely told the LSPV that there is no weight in the rear end, therefore braking force to the rear brakes is reduced. Many lift kits come with a bracket that is used to raise the end of the arm that extends to the rear axle the same distance as the lift, this returns the LSPV to its regular specs.
Old Aug 4, 2011 | 09:29 PM
I guess I type too slow.
Old Aug 4, 2011 | 10:03 PM
a buddy is saying to cut it off and zap strap it up...
Old Aug 4, 2011 | 10:30 PM
anthony1's Avatar
This is what mine looks like now...It's adjustable.
Old Aug 4, 2011 | 11:20 PM
I like it! thanks
Old Aug 5, 2011 | 07:25 AM
x2, that's a great idea. I've done the zip tie thing but they don't last long in AZ. I'm going to give this a shot as well.
Old Aug 5, 2011 | 07:41 AM
4Crawler's Avatar
x2 on the turnbuckle setup, I used the turn buckle setup for many, many years:
- http://www.4crawler.com/4x4/4R_suspe...ortioningValve
We make custom length LSPV brkts. if you want to go that route:
- http://www.4crawler.com/4x4/ForSale/...l#LSPV_Bracket
Old Aug 5, 2011 | 08:35 AM
Dutchbelly's Avatar
Another option here. This is a quote from one of the posts in my build thread:
Originally Posted by Hadmatt54
On the brake issue, if you want to get tid of the proportioning valve at the rear of the vehicle and only have to run one line back to your rear brakes, I have a solution for you...at least this is what I did and my brakes have not given me a minutes problem in 7years.
Any vehicle that has disk brakes in the front and drum brakes in the rear has some type of proportioning valve to limit the amount of brake fluid and the pressure to the rear brakes so that your front disks still do the majority of the braking and the rear drums don't lock up.
When I built my truck a used an 88 Cressida as a donor for my 5m-ge engine. I had the complete car. The cressida had factory front and rear disk brakes, but they were of course smaller than my truck, but the cressida had a factory proportioning valve mounted below the master cylinder. I took the 15/16 bore master cylinder and proportioning valve and mounted it in my truck. The master cylinder bolted to my truck booster and I used the factory cressida brake lines that connected the proportioning valve to the master cylinder, fab'd a bracket for the proportioning valve and mounted it to the drivers inner fender. On the passengers side I swapped the fittings mounted to the frame with to "L" fittings (I think these were Cresida as well, or one might have been the trucks front fitting and the other was a cressida fitting, I'm trying to remember back 7 years and most of the time I don't remember yesterday!). I made 2 new pipes from the master across the firewall to the "L" fittings one line went to the passengers front caliper, the other went to the rear flex hose above the rearend. Nice and neat, no more rear valve and the very best of brakes. I installed a rear transfer case brake 7 years ago and I'll be doing a complete rebuild on my pick-up later this summer, with toyota rear disks. I'm going to keep this setup and see how the cressida proportioning valve works with front and rear disks on my truck. I think it will be great, after all that is the system that it was designed for. I'm enjoying your built keep it up.
Old Aug 6, 2011 | 05:30 AM
anthony1's Avatar
I know. I just happened to see it and post it faster than you....How are you, Roger? ...
gillesdetrail
Nov 19, 2019 12:56 PM
voiddweller
19
May 2, 2016 09:10 PM
live4soccer7
Sep 3, 2015 12:29 PM
Mr.Black
Jun 21, 2015 10:17 AM
88Toy
7
Jun 17, 2015 09:40 AM
