left brake drum and backplate soaking in gear oil
Old Sep 12, 2012 | 04:55 AM
bodo4runner's Avatar
hello!left brake drum soaking in gear oil
wheel and tire look something like this...
Old Sep 12, 2012 | 05:12 AM
waskillywabbit's Avatar
That means your rear wheel bearing/seal is gone.
Typical problem with lots of info on repair.
:wabbit2:
Old Sep 12, 2012 | 05:15 AM
scope103's Avatar
I suggest you start here:
http://www.ncttora.com/fsm/1990-1995...e/rearaxle.pdf
Old Sep 12, 2012 | 06:20 AM
vasinvictor's Avatar
Unbolt wheel, pull off drum, un-do the parking brake cable and unbolt (2 10mm bolts), unbolt brake line (10mm), unbolt 4 nuts on backside (14mm), pull out axle completely. Pop out old seal, tap in new one, put together in reverse order. It's realllllllly easy. Good luck.
Old Sep 12, 2012 | 08:53 AM
Keith B.'s Avatar
Be sure to check for bent axle before installing new seal.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
