Laundry List of 22re issues
Old Apr 16, 2018 | 04:39 AM
  #81
skypilot's Avatar
Well; the picture you showed us is the older EGR plumbing, like what I have on my '88. The charcoal canister line must be reversed at the tank top. The line goes to a VSV or to a port on the manifold. It should never have liquid in it.
Also the T-bar adjuster rod has a locking nut on it. They might actually align and "look" like one nut. I suggest loosening the body bolts and wedge the body up a little to give you some room. If you want a winch on the front now is the time to put in bigger bars. Also skip the torch and use a sawzall, safer that way.
Old Apr 16, 2018 | 06:33 AM
  #82
jwicker's Avatar
Thanks, SkyPilot - the charcoal canister issue was resolved some time ago. Yes - lines were reversed by previous owner.
From other research, only a few years in the 80s had a jam nut on the torsion bar adjuster bolt.
Mine is a single sleeve-type nut on the top.
I have new hardware from local Toyota dealer on hand.
I ordered an electric body saw and some blades from HarborFreight.
Awaiting it's arrival to cut out the old torsion bar adjusters.
kyshooter
Aug 24, 2011 04:18 AM
captain_howdy
Feb 6, 2008 07:47 PM
ohio
Apr 25, 2006 03:41 PM
gohawks
Jun 8, 2005 04:09 AM
Ursa Americanus
Sep 20, 2004 03:03 PM
