LandCruiser Coils in rear for 92 4runner
Old Jan 23, 2009 | 08:01 PM
SMOD's Avatar
I'm buying some coils from someone on this site.. he's cool.
I was wondering a few things about these coils.
(I know this topic has been beat to death but I want to be exact).
How much of a difference will the different size coils make when put on the 4runner? (Because one coil is a little longer). Should I cut it to the same size maybe?
With these coils I've heard it will give 3in. to 4in. so will I need to put on longer shocks? brake lines? Will anything else have to be extended?
Thanks
Smod
Old Jan 23, 2009 | 09:03 PM
toyota4x4907's Avatar
I believe the longer one is supposed to go on the passenger side, due to the fuel tank.
Yes, probably brake lines and shocks, but also Panhard bar drop bracket and LSVP lift bracket would be good...
Old Jan 25, 2009 | 11:54 AM
SMOD's Avatar
Is it absolutely necessary to extend the brake lines and get new shocks and brackets???
I don't want to add these things right away... maybe later on but I want the option of not having to do it.
(So should I cut the springs to the same size?)
Thanks
Old Jan 25, 2009 | 04:04 PM
toyminator2000's Avatar
Thanks
You can fabricate a simple bracket to move where the fexible line mounts to the axle up a couple of inches to compensate.
Old Jan 25, 2009 | 05:30 PM
SMOD's Avatar
So does that mean I have to do that???
I just want a simple yes or no answer.
Do I have to replace anything else other than the coils to lift it with the landcruiser coils?
(Also I don't even know what bracket is being talked about.. lol)
Thanks
Old Jan 25, 2009 | 06:00 PM
94Runner4x4's Avatar
you can leave everything unbolted and run it that way or do it the right way the first time. I didn't reattach my panhard bar after, it is now but i left it off for a year. And you can leave out the shocks for now but you will hear terrible noises and the ride will be terrible. If i were you I would buy the drop bracket and the new shocks you would be spending an extra $140 give or take depending on the shocks and you would be doing it the right way.
Old Jan 25, 2009 | 06:16 PM
SMOD's Avatar
does anyone have any pics of the rear with the brackets??
Thanks
Old Jan 25, 2009 | 06:20 PM
i would help out but i literally just did it 2 or 3 weeks ago and haven't taken any pics. but go here http://www.4crawler.com/4x4/ForSale/...rdDropBrkt.jpg and there are instructions for install but it's easy, really easy.
Old Jan 25, 2009 | 06:37 PM
FredTJ's Avatar
Originally Posted by 94Runner4x4
<SNIP>
I didn't reattach my panhard bar after, it is now but i left it off for a year. <SNIP>
If you didn't reattach the panhard bar (track bar) in the rear, you're a simple ido.., errrr, I'll be nice, goof (assuming that you drove it that way) and the fact that nothing major happened while driving it makes you a damnnn lucky one.
The panhard bar is what locates the axle, laterally.
To the original poster, if you end up with 3" ~ 4" of lift then yes you'll need new shocks. You're stock ones will be basically fully extended with 4" of lift.
What are you going to do with the front or do you just want to drive it around with the ass up in the air ?
Why do you want to lift the rear 3" ~ 4" anyway ?
Geezzz, some of the cr$p advice that's given on this forum is almost criminal.
Fred
Old Jan 25, 2009 | 06:46 PM
SMOD's Avatar
I'm going to do 1.5" BJ spacers up front with my IFS.
And I don't want spacers in the rear and I heard about the landcruiser coils.. I rather have coils than spacers.
And I'm going to put on some 33 inch tires.
Where can I buy some of these brackets?
And what size shocks should I get?
Thanks
Old Jan 25, 2009 | 06:47 PM
I've talked to a couple guys on the board and also some shops and from my year of experience I can say nothing happened and it really isn't that unsafe. It didn't hurt anything at all. That was with about 12 to 15 thousand miles driving and a number of wheeling trips too. I wasn't recommending not doing it, but he doesn't seem very eager to do it so i was informing that it was possible to run it without one. But I do recommend completing the whole job and not just half.
Old Jan 25, 2009 | 06:50 PM
o and i also ran mine with the ass up in the air too.... and again there were no complications or problems in doing so.
Old Jan 25, 2009 | 06:52 PM
SMOD's Avatar
I honestly would rather have 2 or 2.5" in the rear lift so the rear isn't higher than the front.
Would it be safe to cut the landcruiser coils to make the lift to 2 - 2.5"?
Or are there any other coils that would give 2 - 2.5" of lift for the rear on the 2nd gen?
Thanks
Old Jan 25, 2009 | 06:54 PM
Well it will be even when you put the BJ spacers in.
Old Jan 25, 2009 | 06:56 PM
SMOD's Avatar
Which set up are you saying would be level with bj spacers?
Old Jan 25, 2009 | 06:57 PM
cruiser coils....there is a whole long sticky about 2nd gen lifts check it out.
Old Jan 25, 2009 | 07:01 PM
stormin94's Avatar
I cranked up the torsion bars to compensate for about 1" of the rear lift. It doesn't look goofy(with the rear in the air, and the front stock). I also have a 1" body lift, and my 33-12.50's still rub.
Old Jan 25, 2009 | 07:07 PM
SMOD's Avatar
So should I run 1.5 BJ spacers with Landcruiser coils and replace the shocks and do brackets in the rear?
Or should I do 1.5 BJ spacers with 2 inch downey coils and leave the rest stock.
(I want my runner to be as level as possible, and to do this lift as cheap as possible.. so I think this would be the best route.. ? You think?)
Thanks
Old Jan 25, 2009 | 07:10 PM
how much are you getting the coils for?
Old Jan 25, 2009 | 07:15 PM
SMOD's Avatar
Actually, the sale fell through, but I found another guy on this site and he wants $45 shipped for the landcruiser coils.
