Jumped the fuel pump via diagnostics ..nothin
Old Mar 27, 2018 | 05:30 PM
Melrose 4r's Avatar
5 Year Member
Originally Posted by K9Kodi
Escalade? I don’t get it
Rad is suggesting in a tongue in cheek kind of way that it's helpful to give us all the details of the vehicle we're trying to help diagnose. Year, engine, transmission, mileage etc.
Old Mar 27, 2018 | 05:37 PM
SomedayJ's Avatar
Include info about your truck in your signature, some members don't know the vehicle you have.
Old Mar 27, 2018 | 06:37 PM
RAD4Runner's Avatar
Originally Posted by muddpigg
OP do you have a copy of FSM?
I don’t...
LOL! And what FSM shall we share with you? See signature.
Old Mar 28, 2018 | 10:49 AM
K9Kodi's Avatar
Oh my bad. It’s a 1988 pickup xtended cab 4x4 22re
Old Mar 28, 2018 | 12:40 PM
  #25
RAD4Runner's Avatar
Cool. Please see signature.
Do checks as Scope says^^^ WITHOUT TAKING ANYTHING APRT NOR REPLACING THINGS.
(https://www.yotatech.com/forums/f116.../#post52394368)
Here are the things to check mentioned above.
Old Mar 29, 2018 | 07:27 AM
  #26
K9Kodi's Avatar
Thanks for everyone’s help I located the issue. Shotty fuel pump. Thanks a ton guys
Old Mar 29, 2018 | 01:46 PM
  #27
skypilot's Avatar
Did this truck sit??? And I do mean sit without running for a month or more??? Open the gas tank and smell, Kerosene or alky gas? If you can pull the pump and look at the gasoline with a flashlight. if it looks rusty or dark or anything foul ....... the pump is toast. real cheap on ebay, shop around for the right one. They do not last once wet, the alky gas kills'em fast. Yours may be just a spent case.
Old Mar 29, 2018 | 02:20 PM
  #28
Co_94_PU's Avatar
Yet another inconclusive "solved" problem
OP, it helps the people with similar issues if you give details. Otherwise we/they are left to make assumptions. .
Did you have power (voltage and current) at the pump, was it a corroded wire or connection or a truly blown pump (no continuity from pump terminals)..
Old Mar 29, 2018 | 03:51 PM
  #29
K9Kodi's Avatar
Sorry, yea the truck sat for about a year. My problem was
engine cranks, no fuel to motor. I jumped the diagnostics box under the hood next to the fuse block. I did not hear a pump run. I know there are other steps and maybe a diff Oder to diagnose the issue but I had easy access to top of the fuel tank and with the diagnostics plug jumped I had power to the connection for fuel pump but it wasnt on. So I just bought a replacement and the pump works
Old Mar 29, 2018 | 09:52 PM
  #30
RAD4Runner's Avatar
...I did not hear a pump run. ...I had power to the connection for fuel pump but it wasnt on. So I just bought a replacement and the pump works
Good. Thanks for the details.
sbrendle
Apr 9, 2020 11:53 AM
jzx81
Apr 25, 2016 07:06 AM
gromsurf
Apr 24, 2013 08:01 AM
desertcamper67
Dec 26, 2008 10:45 PM
pharoahchillirunnR
Mar 19, 2003 10:21 PM
