ISR mod leak question
Old May 9, 2009 | 09:05 PM
taikowaza's Avatar
I've got an ISR tube and I realized today that the seals on the inlets aren't airtight.
When I cover the edges of the seals, the idle cleans up and gets stronger. I'm psyched that I found this issue but I'm not sure of the best way to seal up these two valves. I'm enclosing 2 pics to give you an idea. Thanks a lot
Attached Thumbnails ISR mod leak question-photo_050909_001.jpg.jpg   ISR mod leak question-writing.jpg
Old May 9, 2009 | 09:10 PM
toyota4x4907's Avatar
Use a little FIPG around the outside, maybe.
Old May 9, 2009 | 09:11 PM
gary96360's Avatar
lol i think i now know why my idle is kind of weird. randomly goes to like 1500 rpm at lights and stufff. i didnt even bother to seal up the homemade isr inlets hah. thanks for the help hehe
Old May 10, 2009 | 12:03 AM
vital22re's Avatar
totally a bro
silicone sealant on the threads put them in and then make sure you seal the out side
Old May 10, 2009 | 12:33 AM
snooze's Avatar
When I made mine, I drilled the hole just big enough so I could thread the fittings into the plastic itself so it would fit nice and tight, then I put an o-ring on the fitting plus some high temp def-con on it. No leaks here
You might want to try putting an o-ring on if you haven't already then spread some def-con/plastic epoxy on it. Hope this helps.
Old May 10, 2009 | 07:06 AM
taikowaza's Avatar
Thanks guys. Is either one one of these the stuff you're both talking about? (just one, or both?) Looking forward to getting an airtight seal! Thanks again
3M™ Ultrapro™ High Temp Silicone Gasket, 08672, Black, 3 oz Tube
3M™ Super Silicone Seal, 08661, Clear, 3 oz Tube,
Old May 10, 2009 | 07:15 AM
mmcpeck's Avatar
I'd try just wrapping the fitting with some Teflon tape, just wrap it 3 or 4 times, it will take you 3 seconds and you will know right away if it works, you don't have to wait for anything to dry.
Old May 10, 2009 | 08:31 AM
Jay351's Avatar
Use some silicone. I used clear RTV to seal up the connetions on mine. I didnt want to use nuts inside of the intake
Old May 10, 2009 | 11:58 AM
taikowaza's Avatar
Thanks guys. I'm going to pick up some RTV today and some new hose clamps. Looking forward to getting that ISR tube airtight. I also found a loose spark plug yesterday, (cylinder 5, hardest to access w/headers! Damn Reed/EGR valves!) all tightened now with new wires and I can already feel the difference. With this leak sealed I'm looking forward to some nice driving! Thanks again for the tips
tj884Rdlx
Aug 28, 2015 12:04 PM
Massmayhem247
Jul 18, 2015 05:46 AM
Coreyr384
Jul 10, 2015 11:13 AM
Avenged
Jul 9, 2015 07:55 AM
Nickdigg
Jul 7, 2015 06:04 AM
