irratic vss signal after 5.3/4l60e swap
Old Jan 5, 2009 | 11:24 AM
sonnyg88's Avatar
After swapping 5.3/4l60e to Toyota dual transfercase using downey 3 piece adapter tranny will not shift on its own. Vss signal is very irratic. Able to shift tranny using scanner, and manually upshift into 2nd. Any ideas?
Old Jan 5, 2009 | 10:09 PM
thook's Avatar
What transmission are you using? Knowing that would help a lot.
Old Jan 6, 2009 | 01:01 AM
Bigblock's Avatar
It says 4L60E.
Bigblock
Old Jan 6, 2009 | 12:32 PM
thook's Avatar
Hehe........I didn't know that's what that meant. Thanks.
Still........not a clue.
Old Jan 7, 2009 | 01:48 PM
sonnyg88's Avatar
Found the position of the VSS(vehicle speed sensor) has to be lined up almost perfectly straight up and down. Had to grind the adapter down where the VSS sits to make it sit right. Very pleased with the outcome. Gonna try it out htis weekend.
Old Jan 7, 2009 | 02:32 PM
Ed H.'s Avatar
do you have any pics of your rig?
ghostmoney
Jan 28, 2018 11:42 AM
Shoua
13
May 22, 2016 05:19 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Esibnitsud
Jul 30, 2015 08:19 PM
wilbertd
Jul 6, 2015 07:39 AM
