Inu's black hole of ?
Old Apr 27, 2013 | 11:55 PM
Inu's Avatar
Inu
Im gonna use this thread as a place to ask oppinions and advice. Along with some humer.
95 4runner 3.0 auto factory 4.88 truck
Done things
Bj spacers and mild coil spacer in back
Poly bushings all a arms
3/16 steel skid from front control arm to transfercase.
Tg front bumper
Sliders and bumpers
Crower cams
Imco 2.5 muffler
Cb mounted on front bumper
Metric Mtr 33's on Tundra steels
Want to get to
Lock f/R
Hidden snorkel
Cage. Debating internal, exo, or fenderbars with internal
Roof rack
80% street, 10% high speed trail, 10% rocks...well baby rocks. Im sticking to bullfrog not the hammers for a while.
Any places I should brace while I have the welder out. I plan to keep thing near the same for a while and gear towards armour lockers and shock placement
Thanks
Old May 11, 2013 | 09:18 PM
Inu's Avatar
Inu
Sliders are on. Still need to nonslip the top.
Im starting on the rear bumper. Still debating just using a reciever shackle or points off the frame. Im already pretty far out for future swingout and the benefits starting to not outway the departure angle for the tube bumper.
Any thoughts?
Old May 28, 2013 | 05:53 PM
Inu's Avatar
Inu
Can still operate the tire lift.
Old May 28, 2013 | 06:57 PM
slo6i's Avatar
I like what you have going there with the sliders and the rear. You fabbed those? Specs? Can I steal the design?
Old May 28, 2013 | 08:33 PM
Inu's Avatar
Inu
Its all from 1 1/4 pipe bent with hf pipe bender. I used some scrap ex tube to keep the rollers from dinging the pipe. I can get full 90s with it. Sliders have 4 legs each with 3x4 1/4 in scab plates. Rear bumpets has the center of the stock hitch and uses the 3/8s drop plates for it as well. If you want a diffrent shot or measurments let me know. Alot of this was scraps i picked up. Steal away. I did
Old May 28, 2013 | 08:55 PM
slo6i's Avatar
Hell yeah! Measurements would be awesome! I just found a sketchup model that im going to use for my front bumper. Unfortunately, I cant answer any of your questions.
Old May 28, 2013 | 09:55 PM
Black_1985_SR5's Avatar
Looks great keep up the good work
Old May 28, 2013 | 10:12 PM
Inu's Avatar
Inu
Thanks. Ive been wanting to do these for a while. Finally got my 220 for the welder and the rust is thick on my fab skills but there functional. Btw mobile home parks suck. I hate the 7 pm quitin time.....
Old May 29, 2013 | 04:18 PM
Inu's Avatar
Inu
Sliders are 63" probly could be 61" for more trim room. I put 4 1/4 between the tubes. Angled them up 1 1/5 in. I tucked mine really tight so had to knotch the pinch seem. On the bumper its pretty much built of the truck. Its a tight fit sliding it on. Still trying to figure out a brace for the wings. Wing are 1 1/2" at the corner. If you use a new receiver you can get things to work without the notches. Used a chop saw for all knotches grinder for cleanup. Still need to face off the main supports.
Old Jun 20, 2013 | 03:13 PM
Inu's Avatar
Inu
Well spent a little time checking the afm. Found out im maxing the thing out. Door stops at .40v, full throttle over 4000 is right there. Treid to wire a resister to drop it to .20 but apparently i suck even with a 10k pot.....im waiting on a gauge to install for fuel pressure to play with that. I just need to bring the afr down from 13.5 so hopefully a little fp and tuning the afm for cruise will do it.
As a side note. If you read this MudHippy, you were right. The system isnt adaptable enough. Still cant believe it maxed the meter with just cams and a catback.....
Old Jul 8, 2013 | 10:48 PM
Inu's Avatar
Inu
Thinking...plus a few fingers of Jim beam. Any thoughts folks?
Old Jul 17, 2013 | 12:31 PM
Inu's Avatar
Inu
fab fubar
As you can see i ditched the plate idea.now for my fubar. I copied the angle on the wings for the support tube. On the right side i must have messed up becouse its gonna rub, were the left side has enough room to flex.
I started to roll the flange back but its not gonna work to well. Any suggestions? If i had a ground anchor i would try to winch the wing down.. ..innexperience bites me again.
Old Jul 17, 2013 | 02:52 PM
Inu's Avatar
Inu
After welding up the driverside i came up with solution without cutting. I set my floorjack under the frame and ran some rachet straps through the crossbar of said jack. Then i just jacked away. Took all my jack had but imanaged to tweak the tube down enough i wont hear any body noise.
Old Jul 30, 2013 | 04:07 PM
longshot454's Avatar
INU do you have a part number for the cam shafts i don't see them listed on crowers site! Thanks and badass looking runner!
Old Jul 30, 2013 | 04:34 PM
Inu's Avatar
Inu
They reground my cams. If I was to do it again I would go through Colt Cams. They were the ones who offered to help with shims if I didnt find a local shop. Crower left me holding the cats tail. Colt is the company that reground weazy's cams. Also do an evaluation, the 3.0 pretty much just enough to get around even after messing with it. I like to tinker.
Crower cam card, grind special F, notes B 1845 in and ex F1
Thanks for the compliment, its coming along. Just need to get the suspension working a little better and lockers. Im a little tired of the bypasses and missing some club runs from tire size and no locker.
Old Jul 30, 2013 | 04:39 PM
I feel ya. Next time we do a run up to big bear area i will let you know. I am in orange county and have a group of guys i go with. They dont care what you have and you can do as much as you want but be ready to take some crap if you fail or do damage. I will contact Colt. I have Heard good things. I am having my heads ported and polished as well to go along with the cam. Also doing a full rebuild kit from LCE so hoping all that will turn into a sold running 3.0. Also got my hands on some MASS airflow stuff so going to convert it and tune it!!!
Old Jul 30, 2013 | 04:54 PM
Inu's Avatar
Inu
Sounds like you got a plan.
Our club is mostly jeep but some toys and a couple scouts. Nondenominatinal wheeling. They let me get in as much trouble as i want. We love guests as well. www.victorvalley4wheelers.com if your in the area when somthings going on come on by. Fun in the desert is coming up in October as well.
Old Jul 30, 2013 | 05:02 PM
Cool man will do. October starts a year of hell for me. We are doing Pismo in September should be fun!
Old Jul 30, 2013 | 06:33 PM
Inu's Avatar
Inu
Old Aug 7, 2013 | 10:52 PM
Inu's Avatar
Inu
Flame Thrower injectors install and tuning
