Installing a 87' 22re in a 94 pickup ??'s
Old Mar 4, 2015 | 04:07 PM
Doug4320's Avatar
I traded a motorcycle for a 1994 4x4 pickup with a 22re. The odometer on the truck said 264,000. I no sooner than got the truck home and realized it needed a timing chain. Previous owner swore the truck had an engine from an RV and only 130,000 miles on it. I installed a timing set,new oil pump and water pump from engnbldr. Ive put 4,000 miles on the truck since. I recently installed flamethrower injectors too. Anywho I was absolutely raping the poor girl the other day. I was pulling my buddies UTV out from 2 ft of snow. While doing so the engine developed one hell of a knock. A friend of mine that that drag races and puts engines together says it sounds like I broke a wristpin. I found a 1987 22re with 75,000 miles for $500. I figure this route is cheaper/faster than rebuilding mine. What do I have to do to make a 1987 22re work in a 1994? Research tells me the fuel/electrical systems are different. I'm not sure I can acquire the 87 ECU. Also should I swap the new timing set from my 94 to the 87? The 87 engine was pulled from an RV.
Old Mar 4, 2015 | 04:11 PM
bswarm's Avatar
If it broke a rod pin it'll have one heck of a miss. More likely a rod bearing.
Old Mar 4, 2015 | 04:23 PM
muddpigg's Avatar
I'm assuming it's the 22RE '87. I think there was a few that we 22R. But even if it is engine, head, valve cover, oil pan. The lower intake plenums are the same for older and newer 22RE. compare sensors and use ones off your engine. Shouldn't need new ECU. Don't know if manifold is different. Your motor should have a wide band O2 where 87 has narrow.
Take time and compare parts.
Old Mar 4, 2015 | 04:44 PM
Doug4320's Avatar
Thanks.I think swapping sensors should work. I've read my 1994 has more emissions. Intake manifolds I'm unsure of. My non cali 94 does only have narrowband O2.
Old Mar 6, 2015 | 07:24 AM
lethe's Avatar
I did the opposite and swapped a engine from a 94' into my 87'. Just strip the 87 down to a long block and bolt your 94' accessories and intake manifold onto the 87'.
Old Mar 6, 2015 | 12:32 PM
Doug4320's Avatar
Thanks for the reassurance! I jus got home with the new engine. The only other issue I have is the 87 came out of a truck with auto trans. My truck is standard. I am told I will have to install a pilot bearing?
Old Mar 6, 2015 | 12:39 PM
bswarm's Avatar
Yes, most definitely.
Old Mar 6, 2015 | 01:24 PM
Doug4320's Avatar
87 and 94 pilots bearings the same?
Old Mar 6, 2015 | 01:27 PM
bswarm's Avatar
I'm pretty sure they're all the same. http://www.lceperformance.com/Pilot-...-p/1054003.htm says they are.
Old Mar 6, 2015 | 01:29 PM
Doug4320's Avatar
Thanks!!
Old Mar 22, 2015 | 04:06 AM
Doug4320's Avatar
Done!! Up and running!!!
Old Mar 27, 2015 | 08:38 AM
muddpigg's Avatar
Awesome!!
sonic concepts
Aug 16, 2025 03:13 PM
puddlepirate
Jun 30, 2015 05:08 PM
Iceman4193
Jun 28, 2015 10:30 AM
zytra
Jun 24, 2015 08:14 AM
Old Red 94
Jun 16, 2015 08:32 PM
