install studs without removing the head?
My 87 4Runner's engine has recently been rebuilt, but I think a different cam should be in it.
Since I'll have the head bolts out to R&R the cam, I was wondering if I would be able to install studs without removing the head? Can't say I've ever installed studs, so be gentle!
TIA!
TIA!
Well, that's the plan. Found quite a few pages which indicate that, as long as the gasket seal isn't broken, it's safe to do. Make sure to drain antifreeze completely to avoid floating the head off the block, etc.
I'm not excited about the idea, but it seems that the vast majority of threads/pages on doing it do it that way.
it has about 5000 miles on it since it was rebuilt, so it's not a preventative maintenance that would make sense to do.
I swapped a cam and head bolts with out doing a head gasket a couple of years ago and I have had no issues with it so far..
If that makes you feel any better..
I kinda wish I would have put in ARP studs...
It's a risk but like you have seen by researching it can be done. What's wrong with the old studs? why arp. i know they're all good and well but don't see many guys running them. Then again i thought of using arp's when i rebuilt my last 22re so can't shun you for that. Do it and give some feedback.
sure it's a risk; if you disturb the head gasket, you'll end up with problems
but at the same time, if you've ever removed the head from a block, you know how well they can stick together, so you might be fine if the head gasket has some miles on it
but personally, were it me, I'd just get a head gasket kit at the same time and do it, but I'm not that big of a risk taker...
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
