INJECTOR LEAK! what the freak!
Old Sep 25, 2008 | 07:37 PM
BAMF_3521's Avatar
Angry INJECTOR LEAK! what the freak!
ok so here i am thinking my baby was ready to roll. then i found the injector closest to the firwall leaking. Im guessing i need some new o-rings. Well i got about 2 hours of tear apart headed my way to inspect the problem. hopefully im right.
Old Sep 25, 2008 | 07:40 PM
fillsrunner4's Avatar
That would be my guess! Good thing O-rings are cheap!
I had leaking injectors but it turned out to be a clogged fuel pressure regulator. Ide test yours when you take it apart. I blew compressed air to see it it would open and it would not. I replaced it and was good to go. Just another thing it may be
Old Sep 25, 2008 | 07:42 PM
BAMF_3521's Avatar
i really hope its just the o rings.
Old Sep 25, 2008 | 07:43 PM
Hopefully! the new FPSU isnt to expensive just be sure to check it while your down there!
Since its one I would bet its just o-rings though
Old Sep 25, 2008 | 07:46 PM
BAMF_3521's Avatar
WORD. i will
Old Sep 26, 2008 | 04:05 AM
wardriver's Avatar
Assuming you have the V6...
When I had my engine apart for my head gasket I had leaking injectors - TWICE! I did learn a trick though. Once you have your injectors in, fuel rails on, regulator installed, and gas line in place...Turn your key on to run - but not start and energize the fuel pump in the diagnostic port next to your under the hood fuse box. I believe the pins are P and FP. Should be the corner pins closest to the passenger firewall. Just use a paper clip to jump the pins.
But doing this once it is buttoned up will tell you if you have an injector leak before putting the plenum back on.
Edit- your profile says you have a "V4" Not quite sure what to make of that - but the process should be the same for the 22re
Blamalam
Mar 12, 2022 07:34 AM
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
romex1
Aug 10, 2015 06:21 PM
HookahRoo
Jul 20, 2015 07:06 PM
