Trouble with t-case/front driveline/front axle
Old Sep 25, 2008 | 04:28 PM
Tortuginator's Avatar
Ok, I've got a problem with my 88 yoter's front drivetrain. There is a loud clunking that comes from down there, only when I'm moving. Usually it doesn't happen when in 2 wheel. It is difficult to explain, cause it comes and goes. Um, mostly happens when in 4wheel when driving at a down angle.
Front end is locked, 4in. a-arm drop/lift. T-case is stock, as well as drive shaft.
If anyone can help, i'd appreciate it. Thanks.
Old Sep 26, 2008 | 04:35 AM
jsn_stockard's Avatar
Check the bushings on the front diff. If they are bad it will let it jump under a load.
Longbed 90
Mar 11, 2019 12:38 PM
Bourbonblues
Dec 15, 2017 05:43 PM
89hilux1
Sep 14, 2015 06:13 PM
Boomer8404
Sep 10, 2015 09:01 AM
128keaton
Sep 3, 2015 05:09 PM
