IFS Suspension Rebuild - IT HAS BEGUN!!! PICS!!!
Old Mar 9, 2009 | 02:26 PM
  #61
iamsuperbleeder's Avatar
Originally Posted by flashkl
The one thing I think you shoulda done while evrything was apart was the control arm bushings...
Yeah I thought about those once I had everything torn down, but I don't think I would have had the time really...
plus they still felt pretty solid, so I'm not too worried about them
thanks!
Old Mar 12, 2009 | 11:24 AM
  #62
Well I just returned not even 30 minutes ago from my 3 hour trip to, and 3 hour trip back, down to southern Florida
All of the work DEFINATELY paid off! The truck ride so nice at 80mph +
Reinstalling the sway-bar and new end links was a great idea, cause it cut the body roll down quite noticeably, and it felt really good around long curves on i95
No more vibrations/occilations, no more pulling to the left, no more being blown all over the road by small gusts of wind; it's really nice to feel safe in my own truck again
This weekend I'm going to crawl back under the truck for a final torque down of all the BJ-bolts and what not, just to be sure
If I put 438 miles on my truck every week like I did this week, I'll reach 300k in no time
Old Mar 12, 2009 | 11:36 AM
  #63
DeathCougar's Avatar
I get to do this all to my Dodge in the coming weeks.
Except my parts are going to cost $750 :thumbsdown:
Old Mar 12, 2009 | 11:47 AM
  #64
well let's see, this little project was a total of about $950 worth of parts (that's with tires, but not including the alignment)
not including the other $20 I had to spend on a new 22mm socket and wrench, cause I still have no idea where my old one ran off to
Old Mar 12, 2009 | 11:54 AM
  #65
$750 is only a track bar, and 4 tie rod ends. The alignment is gonna be another $200! Yikes!
Dodge parts are $$$$$$$$$$$$$$$$
Old Mar 12, 2009 | 12:12 PM
  #66
T4L's Avatar
T4L
Nice work, bleeder. Helps me feel a little better about some work that I'm sure I'll be doing soon. I already recently replaced shocks and CV axles.
Old Mar 12, 2009 | 03:57 PM
  #67
scuba's Avatar
Uhmmm Travis...What happened to the ranco UCA's ??
Old Mar 12, 2009 | 03:59 PM
  #68
yeah I know...
you didn't catch my other post, did you...
https://www.yotatech.com/forums/f116...pickup-168572/
Old Mar 12, 2009 | 04:20 PM
  #69
scuba's Avatar
I have add, I got to post 3 and couldnt read anymore...You just dont feel like putting them in...? Panzy..
Old Mar 12, 2009 | 04:24 PM
  #70
lol, at the moment it just wouldn't be a good move to start really modifying my truck like this; once I get another vehicle, it's on
Old Apr 10, 2009 | 09:33 PM
  #71
87TwentyTwoR's Avatar
i need to install new tire rod ends and new idle arm. would this be difficult to do this myself? i did basic engine stuff but never anything with suspension. 4x4 parts is going to charge me 700 for parts and installation. do i need any special tools? what is that bracket thing down there?
Old Apr 10, 2009 | 09:55 PM
  #72
Originally Posted by Matt16
Best tool ever for IFS.
this part?
Old Apr 11, 2009 | 06:41 AM
  #73
BigBluePile's Avatar
Yes, it's very simple work to do just make sure you pick up one of these tie rod/pitman arm pullers(see below).
this part?
YES!!!! It makes the work easy!!
Old Apr 11, 2009 | 07:12 AM
  #74
t-1hundred's Avatar
nice job! makes me want to do my truck lol
  #75
BigBlue's right, that's all you'll need
just make sure you get an alignment done (unless you trust you'r skills enough to do it yourself), beacuse the tow will be messed up when you're done
Old Apr 11, 2009 | 08:29 AM
  #76
DO IT! ! !
It's real simple, pick up some PB Blaster and that tool. I like to use torque wrenches and they're worth it if you do a lot of your own maitenance.
Old Apr 11, 2009 | 06:17 PM
  #77
tie rod/pitman arm pullers. ok thanks... how exactly do you use it?
Old Apr 11, 2009 | 06:19 PM
  #78
waskillywabbit's Avatar
Tighten on the pitman arm or the TRE and hit it with an impact.
If no impact, tighten it up, hit end with 3 lb sledge, tighten it as much as possible again, repeat. Eventually it will pop the pitman arm or TRE off.
Old Apr 11, 2009 | 06:22 PM
  #79
ok thanks.. ima try to do this stuff myself but i think this will be the toughest project ever done on my truck so far.
Old Apr 11, 2009 | 06:23 PM
  #80
MAKE SURE TO LEAVE THE NUT ON!!!!!!! Either the balljoint or the TRE! 'Cause sometimes they come off, sometimes they POP off!!!
