IFS to SAS
Search SAS and there will be a ton of builds and tech info on many different kinds of solid axle swaps.
and I'll agree with toylocost; if you have to ask, you probably don't need it, and will probably be overwhelmed if you were to dig into it right away with a LOT or research
as 89 said, search; the YT forums are FILLED with SAS threads
honestly, pretty simple.. so far iv done my own SAS and helped out on two others. can be a pain at times.. make sure you have all your parts, tools, and materials ready. expect to use every cuss word in the book and possibly create some new ones. it really helps to have a torch or a plasma handy, you will need them for doing the frame tubes, though i have heard of people using a hole saw.. not so fun in my oppinion. you can cut the ifs brackets off with a sawzall or a grinder if you like, its dirty and takes longer but if you dont have the torch it can be done. It took me and a friend a weeknd to get my runner all done. just be precise.. and if something just doesnt look right, its probably not.. take it apart and try again. on my 4runner the biggest PITA was having the cut the front drive line bolts off at the t/c, the PO locktighted and rounded them off... hence the use of excessive cursing lol but once you drop it on all 4 tires and see what you have accomplished it is well worth it.
From: Yotatech, because Pirate is too expensive. NorCal.
Now theres a good answer.
I used a hole saw on the frame tubes and broke 5 pilot bits and created 15 new profanities
->Overall though he didn't ask whether or not he needed it, he asked how hard it was.
what's a web wheeler?
and i agree with tc. go out and wheel a little, find out how far you can go with what little flex you have and if you dont like it do the sas. thats my next job. from what i'v seen they dont look too hard. just take a little time and experience with cutting and welding and a little mechanics. either way good luck
you have a point, he didnt ask whether he needed one or not, only he knows if he needs a SAS or not. he may may be a newb to an SAS but he may not be a newb to wheeling.
i personally dont have the experience or the tools to do an SAS myself, but i am far from a newb to wheeling.
i need an SAS too though, and so do u lol
some one who's online talking about wheeling or trucks and stuff more than actually going out to wheel.
