IFS Flex Pics
Old Nov 21, 2013 | 10:02 PM
  #1641
Z's Confederate Toy's Avatar
Old Nov 22, 2013 | 05:03 PM
  #1642
Red Wagon's Avatar
Nate, you have a supra front diff in there right?
Old Nov 22, 2013 | 05:49 PM
  #1643
BlazeN8's Avatar
No its my original 7.5 diff with the driver side "long tube" unbolted and a second stub axle plugged in. You have to use a 7.5 diff that uses hubs as the ADD style wont work. Grind off about 1/4" of material from the housing so the stub axle clears. Also install a new seal with the right size diameters. Plug and play!
For the CV axles, I cut a standard 4x4 CV axle "center bar" in the middle and sleeved it with some 1-1/2" DOM with 1/4" wall to extend the length. For the sleeves I matched the I.D. on the lathe and press fit the O.D of the cut center bar. I drilled some holes and plug welded as well as a perimeter weld.
I did build a Supra8 hanger bracket (check out the website) but didn't get to installing the 5.29 gears yet. I just ran out of steam and funds for the re-gear and ARB. My Supra8 is an LSD so I may not do the ARB, just the re-gear.
And oh yea, I have to break the 7.5" before I deem it not worthy!
Contact me off line for more info or if you want me to build you an axle sleeve kit or send out to have a custom center bar machined. I have build blueprints at the machine shop.
Old Nov 22, 2013 | 05:54 PM
  #1644
Red Wagon's Avatar
Yeah Tim said the 7.5 has worked well for him locked on 35" tires.
Old Nov 25, 2013 | 12:48 PM
  #1645
vasinvictor's Avatar
don't let this thread die bump
Old Nov 26, 2013 | 06:20 AM
  #1646
Yamiryder's Avatar
Old Dec 3, 2013 | 01:25 PM
  #1647
krhoda5's Avatar
I realized I don't have any good off-road photos of my truck. I need a friend with a good camera!
I'm cycling 15" of wheel travel in the front w/ IFS.
I'll make it a point to get some flex pics next time I'm out.
Old Dec 3, 2013 | 04:46 PM
  #1648
ChefYota4x4's Avatar
Sick!
Old Dec 3, 2013 | 04:52 PM
  #1649
BlazeN8's Avatar
On factory LCA pivots, UCA cross shafts and w/ 4WD? Nicely done!
Old Dec 3, 2013 | 05:04 PM
  #1650
krhoda5's Avatar
Im still waiting for RCV to get the '86-'94 CV shafts on the market. I talked to them today, they are still having testing issues. They said another year maybe. bummer. I snap the stock outer CVs like nothing.
Old Dec 3, 2013 | 05:19 PM
  #1651
BlazeN8's Avatar
I'd be surprised if RCV can ever get T-100 length CVs to work with anything more than 13" of travel. This is why some of us have migrated to Center Mounting the Diff and running even longer CVs.
Old Dec 3, 2013 | 05:41 PM
  #1652
krhoda5's Avatar
I'm getting 15" with the 930 inner CVs, I just keep snapping the end of the stock outer off right at the snap ring groove. I've looked into the center mounted dif. I would have to re-engineer the front end to clear the 3.4 V6 oil pan. I just need to learn to keep my foot out of the throttle when I'm in 4 wheel drive until RCV comes through with the 4340 shafts.
Old Dec 4, 2013 | 12:39 AM
  #1653
JonnyBoy's Avatar
I know somewhere earlier in this thread someone said no "flat ground pics" but here's a flat ground flex pic without using ramps
Old Dec 4, 2013 | 03:22 AM
  #1654
jb451's Avatar
Terrible pic, but i'm contribootin'.
Old Dec 4, 2013 | 10:34 AM
  #1655
Sweet! The video background I have in my mind is helping to make that picture even more badass! You were having fun man!
Old Dec 4, 2013 | 03:56 PM
  #1656
JonnyBoy's Avatar
Haha, that was after the half wheelie Mark, just pulling back up to my passenger/videographer. I did pull a still of the wheel off the ground from that video, but that's showing lack of ifs flex more than ability to flex, so I figured this one is more appropriate. And my first contribution to this thread.
Old Dec 5, 2013 | 01:07 AM
  #1657
TNRabbit's Avatar
Old Dec 8, 2013 | 09:37 AM
  #1658
krhoda5's Avatar
Here u go!
Went out this weekend and got some good pics.
Attached Thumbnails IFS Flex Pics-img_0218.jpg   IFS Flex Pics-img_0204.jpg   IFS Flex Pics-img_0206.jpg
Old Dec 8, 2013 | 09:45 AM
  #1659
Cool pics guys.... Love em! TN, how u been?
Old Dec 8, 2013 | 05:44 PM
  #1660
JonnyBoy's Avatar
Went out and tested my reinstalled 4wd stuff
